LTT guide for building your own Router
Video Overview
    • To get things ready you are going to want to open your machine up and give it a good dusting, and depending on how old it is, maybe replace the thermal paste.
    • If you haven't yet, it is recommended that you upgrade your processor and your storage to a single 256 GB SSD.
    Ask FixBot
    • Once your device has been cleaned, install your Network NIC into your PCIe slot.
    Ask FixBot
    • Using your USB Drive, create a live boot of OpnSense.
    • Typically you can write it with Etcher, or Win32DiskImager to create this.
    • Plug it into your soon-to-be Router and select the device from your boot manager.
    • If your machine happens to have an internal speaker, you may hear a beep. While not annoying, it may be surprising if you're not expecting it.
    Ask FixBot
    • During the boot sequence, it will ask for manual input, but you can skip these steps.
    • Once you are prompted to log in, take note of the port numbering of your system.
    • You can get the numbering by taking the ethernet port from a nearby computer and testing each port. (If you can, physically label these ports)
    • When prompted to log in, do so by using installer as the username and opnsense as the password.
    • When the device reboots remove the USB, otherwise you will reboot back into the installer.
    Ask FixBot
    • Once Opnsense is installed, plug your client system into the port marked as LAN in your console and using a web browser put the IP address 192.168.1.1. This is the default address set by the operating system and should be changed.
    • By default, OPNsense will allow for a range of 100 different IP addresses. You can change this in your IP range settings by modifying the last Octet of the From field to 50. and the last Octet of the To field to 254. This will allow a range of 200 different IP addresses.
    • You can also modify your DNS settings to use Cloudflare (1.1.1.1 for IPv4) or Google DNS (8.8.8.8 or 8.8.4.4 for IPv4).
    Ask FixBot
    • While we have one port assigned on your router, it is recommended that you pair it with an inexpensive multi-port Switch, and a few Wireless Access Points.
    Ask FixBot
Congratulation, you have just created your very own router that can be updated, customized, and configured to your liking. You may also want to consider pairing it with your own custom VPN or your own server.
9 other people completed this guide.
Jacob Mehnert
49,106 Reputation
51 Guides authored
iFanatics Member of iFanatics
Community
69 Members
237 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 88
Past 30 Days: 549
All Time: 28,159
