LINE6 HELIX FLOOR Tactile switches Replacement
  1. LINE6 HELIX FLOOR Tactile switches Replacement, Disassembling the device: step 1, image 1 of 1
    • First step is to disassemble the guitar procesor. That is done by removing the screws from side and bottom of the device.
  2. LINE6 HELIX FLOOR Tactile switches Replacement, Removing the PCB with tactile switches: step 2, image 1 of 3 LINE6 HELIX FLOOR Tactile switches Replacement, Removing the PCB with tactile switches: step 2, image 2 of 3 LINE6 HELIX FLOOR Tactile switches Replacement, Removing the PCB with tactile switches: step 2, image 3 of 3
    • Unscrew the PCB that can be seen on the pictures. Then use a knife to remove the glue sticking the connectors togehter. Be extremely careful doing that since that could destroy your device. Don't forget to unscrew the grounding cable.
  3. LINE6 HELIX FLOOR Tactile switches Replacement, Changing the tacticle switches: step 3, image 1 of 3 LINE6 HELIX FLOOR Tactile switches Replacement, Changing the tacticle switches: step 3, image 2 of 3 LINE6 HELIX FLOOR Tactile switches Replacement, Changing the tacticle switches: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • The old tactile switches have to be removed. This could be done by cutting their pins with cutting pliers. After the old switch is removed, old pins have to be desoldered. Move the heating iron next to the pin and use tweezers to remove the pin from the hole.
    • Use soldering iron and solder wick to remove any residual solder from the holes. Then insert new tactile switch and solder it's pins to the PCB.
    • After soldering the switches to it's place device has to be assembled again. To achive this you have to screw the PCB with switches back to the device. Then plug the flat cables to the connectors and use hot glue gun to stick them into place. Then add a side and back part back to the device and add the remaining screws.
Finish Line
havelka.marek414
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 57
All Time: 1,039
