Up to 20% off select tools
LG-P970 touch screen Replacement
Views: 10K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
98
All Time:
10,362
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace your LG-P970 touch screen.
You can buy this part on amazon http://www.amazon.fr/dp/B00CF29W78
    1. LG-P970 touch screen Replacement, touch screen: step 1, image 1 of 3 LG-P970 touch screen Replacement, touch screen: step 1, image 2 of 3 LG-P970 touch screen Replacement, touch screen: step 1, image 3 of 3
      • remove the back cover
      • remove the battery
      • remove the SIM card
      • remove the µSD card (Memory)
      Ask FixBot
    2. LG-P970 touch screen Replacement: step 2, image 1 of 3 LG-P970 touch screen Replacement: step 2, image 2 of 3 LG-P970 touch screen Replacement: step 2, image 3 of 3
      • remove 7 screws on the back
      • with a tool start to open the back frame
      • and it's now easy to remove the back frame with hand, carefully
      Ask FixBot
    3. LG-P970 touch screen Replacement: step 3, image 1 of 3 LG-P970 touch screen Replacement: step 3, image 2 of 3 LG-P970 touch screen Replacement: step 3, image 3 of 3
      • remove buttons
      • locate the back camera
      • with a tool raise up the led.carefully
      Ask FixBot
    4. LG-P970 touch screen Replacement: step 4, image 1 of 3 LG-P970 touch screen Replacement: step 4, image 2 of 3 LG-P970 touch screen Replacement: step 4, image 3 of 3
      • with a tool disconnect the back camera
      • and remove the camera with your fingers.
      Ask FixBot
    5. LG-P970 touch screen Replacement: step 5, image 1 of 2 LG-P970 touch screen Replacement: step 5, image 2 of 2
      • don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
      Ask FixBot
    6. LG-P970 touch screen Replacement: step 6, image 1 of 3 LG-P970 touch screen Replacement: step 6, image 2 of 3 LG-P970 touch screen Replacement: step 6, image 3 of 3
      • It's time to remove carefully the tactile screen.
      • don't scratch le LCD!!!
      Ask FixBot
    7. LG-P970 touch screen Replacement: step 7, image 1 of 3 LG-P970 touch screen Replacement: step 7, image 2 of 3 LG-P970 touch screen Replacement: step 7, image 3 of 3
      • the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector.
      • cut new double sided tape (1-2mm width), put it on the are and peel it.
      Ask FixBot
    8. LG-P970 touch screen Replacement: step 8, image 1 of 3 LG-P970 touch screen Replacement: step 8, image 2 of 3 LG-P970 touch screen Replacement: step 8, image 3 of 3
      • remove the inside protection on the new touch screen.
      • carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole.
      • to finish, add all part by reading these instructions in reverse ;-)
      • and try if it work !
      Ask FixBot
19 other people completed this guide.
Author
with
Fox4EGX
545 Reputation
1 Guide authored
1 Guide Comment
Hi. To take the screws out do I need a phillips? Thanks.
schutze61 - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 98
All Time: 10,362
