LG-A275 Speaker Replacement
  1. LG-A275 Speaker Replacement, Battery: step 1, image 1 of 2 LG-A275 Speaker Replacement, Battery: step 1, image 2 of 2
    • Turn the phone upside down so that the bottom of the back is facing you.
    Ask FixBot
  2. LG-A275 Speaker Replacement, Remove cover: step 2, image 1 of 2 LG-A275 Speaker Replacement, Remove cover: step 2, image 2 of 2
    • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
    Ask FixBot
  3. LG-A275 Speaker Replacement: step 3, image 1 of 1
    • Gently remove the battery from the device.
    Ask FixBot
  4. LG-A275 Speaker Replacement, Speaker: step 4, image 1 of 3 LG-A275 Speaker Replacement, Speaker: step 4, image 2 of 3 LG-A275 Speaker Replacement, Speaker: step 4, image 3 of 3
    • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
    • Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics.
    Ask FixBot
  5. LG-A275 Speaker Replacement: step 5, image 1 of 3 LG-A275 Speaker Replacement: step 5, image 2 of 3 LG-A275 Speaker Replacement: step 5, image 3 of 3
    • After separating the front and back components of the phone, proceed to take off the motherboard. This can be done by releasing the plastic clamps on the corners and edges of the plastic front using your fingernail.
    • Be careful when doing this to avoid breaking the phone plastics, it should release easily.
    Ask FixBot
  6. LG-A275 Speaker Replacement: step 6, image 1 of 3 LG-A275 Speaker Replacement: step 6, image 2 of 3 LG-A275 Speaker Replacement: step 6, image 3 of 3
    • Lastly remove the speaker using the plastic opening tool.
    Ask FixBot
Nathanael Knight
181 Reputation
2 Guides authored
IUPUI, Team S3-G1, Harley Spring 2018 Member of IUPUI, Team S3-G1, Harley Spring 2018
IUPUI-HARLEY-S18S3G1
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 32
All Time: 574
