Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓In this guide you will be removing the back panel and motherboard to access and remove the inside keyboard.
Tools
Spudger4.9
Place the phone face down on the table.
Pull down the tab below the battery with your fingernail or an opening tool.
Lift the battery out.
Use a metal spudger to remove the five rubber covers and expose the screws underneath.
Locate the silver strip - closest to the bottom hinge of the phone - connected to the logic board.
Wedge the plastic opening tool in between the silver strip and the logic board.
Apply upward pressure with the plastic opening tool to separate the silver strip from the logic board.
Locate the back of the inside keyboard.
Take out the inside keyboard. By using your fingernails to pull one of the corners up, you can snap this piece out of its encasement.
Replace the keyboard by snapping the new keyboard into place, and begin to follow the steps in reverse to reassemble the device.
