Up to 20% off select tools
LG env2 vx9100 Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
19
All Time:
834
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
In this guide you will be removing the back panel to access the motherboard. Once you have reached the motherboard you will remove the camera lens from the motherboard.
    1. LG env2 vx9100 Camera Replacement, Battery: step 1, image 1 of 3 LG env2 vx9100 Camera Replacement, Battery: step 1, image 2 of 3 LG env2 vx9100 Camera Replacement, Battery: step 1, image 3 of 3
      • Power off the phone before disassembly to avoid electric shock or fire.
      • Place the phone face down on the table.
      • Pull down the tab below the battery with your fingernail or an opening tool.
      • Lift the battery out.
      Ask FixBot
    1. LG env2 vx9100 Camera Replacement, Back Panel: step 2, image 1 of 2 LG env2 vx9100 Camera Replacement, Back Panel: step 2, image 2 of 2
      • Use a metal spudger to remove the five rubber covers and expose the screws underneath.
      Ask FixBot
    2. LG env2 vx9100 Camera Replacement: step 3, image 1 of 2 LG env2 vx9100 Camera Replacement: step 3, image 2 of 2
      • Remove all six 2.5 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    3. LG env2 vx9100 Camera Replacement: step 4, image 1 of 2 LG env2 vx9100 Camera Replacement: step 4, image 2 of 2
      • Insert a plastic opening tool into the seam and gently pry to release the tabs.
      • Work around the phone until all tabs are released.
      • Remove the back panel.
      Ask FixBot
    1. LG env2 vx9100 Camera Replacement, Camera: step 5, image 1 of 2 LG env2 vx9100 Camera Replacement, Camera: step 5, image 2 of 2
      • Locate the ribbon attached to the lens of the camera.
      • Place the plastic opening tool in between the logic board and ribbon.
      • Lift up the plastic opening to detach the ribbon from the logic board.
      Ask FixBot
    2. LG env2 vx9100 Camera Replacement: step 6, image 1 of 2 LG env2 vx9100 Camera Replacement: step 6, image 2 of 2
      • Place the plastic opening tool in between the lens and the logic board.
      • Detach the lens from the logic board using the plastic opening tool by popping it out.
      • Take the entire lens and ribbon off of the logic board.
      Ask FixBot
Author
with
Reed Williston
34 Reputation
7 Guides authored
Cal Poly, Team 16-55, Forte Fall 2012 Member of Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 834
