Up to 20% off select tools
LG env2 vx9100 Back Panel Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
18
All Time:
1,247
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
In this guide you will be removing the back panel from the rest of the phone.
    1. LG env2 vx9100 Back Panel Replacement, Battery: step 1, image 1 of 3 LG env2 vx9100 Back Panel Replacement, Battery: step 1, image 2 of 3 LG env2 vx9100 Back Panel Replacement, Battery: step 1, image 3 of 3
      • Power off the phone before disassembly to avoid electric shock or fire.
      • Place the phone face down on the table.
      • Pull down the tab below the battery with your fingernail or an opening tool.
      • Lift the battery out.
      Ask FixBot
    1. LG env2 vx9100 Back Panel Replacement, Back Panel: step 2, image 1 of 2 LG env2 vx9100 Back Panel Replacement, Back Panel: step 2, image 2 of 2
      • Use a metal spudger to remove the five rubber covers and expose the screws underneath.
      Ask FixBot
    2. LG env2 vx9100 Back Panel Replacement: step 3, image 1 of 2 LG env2 vx9100 Back Panel Replacement: step 3, image 2 of 2
      • Remove all six 2.5 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    3. LG env2 vx9100 Back Panel Replacement: step 4, image 1 of 2 LG env2 vx9100 Back Panel Replacement: step 4, image 2 of 2
      • Insert a plastic opening tool into the seam and gently pry to release the tabs.
      • Work around the phone until all tabs are released.
      • Remove the back panel.
      Ask FixBot
2 other people completed this guide.
Author
with
Reed Williston
34 Reputation
7 Guides authored
Cal Poly, Team 16-55, Forte Fall 2012 Member of Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,247
