Up to 20% off select tools
LG Xenon Keyboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
96
All Time:
1,529
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The keyboard is placed on the motherboard but is not attached in any way. This step is easy because there are no necessary tools involved. It is a simple and easy step that allows you to clean the keyboard.
    1. LG Xenon Keyboard Replacement, Back Case: step 1, image 1 of 1
      • Turn the phone so the back side is face up.
      Ask FixBot
    2. LG Xenon Keyboard Replacement: step 2, image 1 of 2 LG Xenon Keyboard Replacement: step 2, image 2 of 2
      • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
      Ask FixBot
    1. LG Xenon Keyboard Replacement, Battery: step 3, image 1 of 2 LG Xenon Keyboard Replacement, Battery: step 3, image 2 of 2
      • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
      Ask FixBot
    1. LG Xenon Keyboard Replacement, Motherboard: step 4, image 1 of 2 LG Xenon Keyboard Replacement, Motherboard: step 4, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
      Ask FixBot
    2. LG Xenon Keyboard Replacement: step 5, image 1 of 1
      • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
      Ask FixBot
    3. LG Xenon Keyboard Replacement: step 6, image 1 of 2 LG Xenon Keyboard Replacement: step 6, image 2 of 2
      • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
      Ask FixBot
    4. LG Xenon Keyboard Replacement: step 7, image 1 of 2 LG Xenon Keyboard Replacement: step 7, image 2 of 2
      • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
      Ask FixBot
    5. LG Xenon Keyboard Replacement: step 8, image 1 of 2 LG Xenon Keyboard Replacement: step 8, image 2 of 2
      • Carefully lift and remove the motherboard from the main body.
      • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
      Ask FixBot
    6. LG Xenon Keyboard Replacement: step 9, image 1 of 2 LG Xenon Keyboard Replacement: step 9, image 2 of 2
      • Carefully unclip the metal tab to separate the connector cable from the motherboard.
      Ask FixBot
    7. LG Xenon Keyboard Replacement: step 10, image 1 of 2 LG Xenon Keyboard Replacement: step 10, image 2 of 2
      • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
      Ask FixBot
    1. LG Xenon Keyboard Replacement, Keyboard: step 11, image 1 of 1
      • Turn the motherboard over and carefully remove the keypad from the motherboard.
      • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
      Ask FixBot
Author
with
Micaela Saqui
78 Reputation
7 Guides authored
Cal Poly, Team 9-41, Regan Spring 2012 Member of Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 96
All Time: 1,529
