Up to 20% off select tools
LG Xenon Battery Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
88
All Time:
2,052
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
If you are having issues with your LG Xenon GR500, before attempting repairs, remove the battery for safe handling.
    1. LG Xenon Battery Replacement, Back Case: step 1, image 1 of 1
      • Turn the phone so the back side is face up.
      Ask FixBot
    2. LG Xenon Battery Replacement: step 2, image 1 of 2 LG Xenon Battery Replacement: step 2, image 2 of 2
      • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
      Ask FixBot
    1. LG Xenon Battery Replacement, Battery: step 3, image 1 of 2 LG Xenon Battery Replacement, Battery: step 3, image 2 of 2
      • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
      Ask FixBot
2 other people completed this guide.
Author
with
Micaela Saqui
78 Reputation
7 Guides authored
Cal Poly, Team 9-41, Regan Spring 2012 Member of Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 88
All Time: 2,052
