Up to 20% off select tools
LG X Style Rear Facing Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
56
All Time:
740
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to remove a faulty rear facing camera in your LG X Style.
    1. LG X Style Rear Facing Camera  Replacement, Battery: step 1, image 1 of 1
      • Power down the device and make sure that it is turned off.
      • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
      • Gently twist tool clockwise until the back case pops open [this will create a small gap].
      • Slide the tool along the gap around the entire device.
      Ask FixBot
    2. LG X Style Rear Facing Camera  Replacement: step 2, image 1 of 2 LG X Style Rear Facing Camera  Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
      Ask FixBot
    1. LG X Style Rear Facing Camera  Replacement, Screen: step 3, image 1 of 2 LG X Style Rear Facing Camera  Replacement, Screen: step 3, image 2 of 2
      • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
      Ask FixBot
    2. LG X Style Rear Facing Camera  Replacement: step 4, image 1 of 3 LG X Style Rear Facing Camera  Replacement: step 4, image 2 of 3 LG X Style Rear Facing Camera  Replacement: step 4, image 3 of 3
      • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
      • Slide prying tool around entire device beginning toward the top.
      • Lift off and remove the screen from the device.
      Ask FixBot
    1. LG X Style Rear Facing Camera  Replacement, Rear Facing Camera: step 5, image 1 of 2 LG X Style Rear Facing Camera  Replacement, Rear Facing Camera: step 5, image 2 of 2
      • Gently use the plastic opening tool to pinch off camera connection tab from motherboard.
      Ask FixBot
    2. LG X Style Rear Facing Camera  Replacement: step 6, image 1 of 1
      • With the plastic opening tool, gently lift up camera housing and remove.
      Ask FixBot
Author
with
cecilia morales
361 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 56
All Time: 740
