LG X Style Motherboard Replacement
    1. LG X Style Motherboard Replacement, Battery: step 1, image 1 of 1
      • Power down the device and make sure that it is turned off.
      • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
      • Gently twist tool clockwise until the back case pops open [this will create a small gap].
      • Slide the tool along the gap around the entire device.
      Ask FixBot
    2. LG X Style Motherboard Replacement: step 2, image 1 of 2 LG X Style Motherboard Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
      Ask FixBot
    1. LG X Style Motherboard Replacement, Screen: step 3, image 1 of 2 LG X Style Motherboard Replacement, Screen: step 3, image 2 of 2
      • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
      Ask FixBot
    2. LG X Style Motherboard Replacement: step 4, image 1 of 3 LG X Style Motherboard Replacement: step 4, image 2 of 3 LG X Style Motherboard Replacement: step 4, image 3 of 3
      • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
      • Slide prying tool around entire device beginning toward the top.
      • Lift off and remove the screen from the device.
      Ask FixBot
    1. LG X Style Motherboard Replacement, Motherboard: step 5, image 1 of 2 LG X Style Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Using the plastic opening tool, carefully slide the edge of the tool under the press fit cable connections and lift up to disconnect. Do this for all three ribbon cables.
      Ask FixBot
    2. LG X Style Motherboard Replacement: step 6, image 1 of 3 LG X Style Motherboard Replacement: step 6, image 2 of 3 LG X Style Motherboard Replacement: step 6, image 3 of 3
      • Using the iFixit opening tool, remove the motherboard from the screen by inserting the opening tool under the edge of the motherboard and lifting up.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 80
All Time: 871
