Up to 20% off select tools
LG X Style Camera Flash Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
6
Past 30 Days:
51
All Time:
762
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the front camera display on your LG device.
    1. LG X Style Camera Flash Replacement, Battery: step 1, image 1 of 1
      • Power down the device and make sure that it is turned off.
      • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
      • Gently twist tool clockwise until the back case pops open [this will create a small gap].
      • Slide the tool along the gap around the entire device.
      Ask FixBot
    2. LG X Style Camera Flash Replacement: step 2, image 1 of 2 LG X Style Camera Flash Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
      Ask FixBot
    1. LG X Style Camera Flash Replacement, Screen: step 3, image 1 of 2 LG X Style Camera Flash Replacement, Screen: step 3, image 2 of 2
      • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
      Ask FixBot
    2. LG X Style Camera Flash Replacement: step 4, image 1 of 3 LG X Style Camera Flash Replacement: step 4, image 2 of 3 LG X Style Camera Flash Replacement: step 4, image 3 of 3
      • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
      • Slide prying tool around entire device beginning toward the top.
      • Lift off and remove the screen from the device.
      Ask FixBot
    1. LG X Style Camera Flash Replacement, Camera Flash: step 5, image 1 of 2 LG X Style Camera Flash Replacement, Camera Flash: step 5, image 2 of 2
      • Using a plastic opening tool, lift up display connection until disconnected from the lower right hand of the phone.
      • Carefully lift the metal connection perpendicular to the mother board.
      Ask FixBot
    2. LG X Style Camera Flash Replacement: step 6, image 1 of 2 LG X Style Camera Flash Replacement: step 6, image 2 of 2
      • Gently lift the camera ribbon cable until the entire front camera housing is removed.
      Ask FixBot
    3. LG X Style Camera Flash Replacement: step 7, image 1 of 3 LG X Style Camera Flash Replacement: step 7, image 2 of 3 LG X Style Camera Flash Replacement: step 7, image 3 of 3
      • Use the opening tool, gently pry up along the edge of the motherboard.
      • Gently pull up and remove the motherboard from the device.
      Ask FixBot
Author
with
cecilia morales
361 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 51
All Time: 762
