LG X Power Charging Port Replacement
    1. LG X Power Charging Port Replacement, LG X Power Disassembly: step 1, image 1 of 2 LG X Power Charging Port Replacement, LG X Power Disassembly: step 1, image 2 of 2
      • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
      Ask FixBot
    2. LG X Power Charging Port Replacement: step 2, image 1 of 2 LG X Power Charging Port Replacement: step 2, image 2 of 2
      • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
      Ask FixBot
    3. LG X Power Charging Port Replacement: step 3, image 1 of 2 LG X Power Charging Port Replacement: step 3, image 2 of 2
      • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
      • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
      Ask FixBot
    1. LG X Power Charging Port Replacement, Charging Port: step 4, image 1 of 3 LG X Power Charging Port Replacement, Charging Port: step 4, image 2 of 3 LG X Power Charging Port Replacement, Charging Port: step 4, image 3 of 3
      • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
      • Pull the cameras out to remove them.
      Ask FixBot
    2. LG X Power Charging Port Replacement: step 5, image 1 of 1
      • Use the flat end of a spudger to disconnect the battery from the motherboard.
      • You will not be removing anything, just disconnecting.
      Ask FixBot
    3. LG X Power Charging Port Replacement: step 6, image 1 of 1
      • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
      Ask FixBot
    4. LG X Power Charging Port Replacement: step 7, image 1 of 1
      • Desolder the MicroUSB charging port from the motherboard.
      • If you need help soldering, follow this guide.
      Ask FixBot
5 other people completed this guide.
Chad Sears
1,200 Reputation
5 Guides authored
USF Tampa, Team S3-G6, Nance Spring 2018 Member of USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Members
72 Guides authored
1 Guide Comment
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - Reply Share
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 80
All Time: 6,652
