Up to 20% off select tools
LG X Power Camera Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
57
All Time:
1,140
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will show how to replace the camera on a LG X Power smartphone.
    1. LG X Power Camera Replacement, LG X Power Disassembly: step 1, image 1 of 2 LG X Power Camera Replacement, LG X Power Disassembly: step 1, image 2 of 2
      • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
      Ask FixBot
    2. LG X Power Camera Replacement: step 2, image 1 of 2 LG X Power Camera Replacement: step 2, image 2 of 2
      • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
      Ask FixBot
    3. LG X Power Camera Replacement: step 3, image 1 of 2 LG X Power Camera Replacement: step 3, image 2 of 2
      • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
      • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
      Ask FixBot
    1. LG X Power Camera Replacement, Main Camera: step 4, image 1 of 2 LG X Power Camera Replacement, Main Camera: step 4, image 2 of 2
      • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
      • Pull the cameras out to remove them.
      Ask FixBot
Author
with
Chad Sears
1,200 Reputation
5 Guides authored
USF Tampa, Team S3-G6, Nance Spring 2018 Member of USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 57
All Time: 1,140
