Up to 20% off select tools
LG X Power Battery Replacement
Views: 21K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
79
All Time:
21,241
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide to help you replace the damaged battery to restore your LG X Power back to its former glory.
    1. LG X Power Battery Replacement, LG X Power Disassembly: step 1, image 1 of 2 LG X Power Battery Replacement, LG X Power Disassembly: step 1, image 2 of 2
      • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
      Ask FixBot
    2. LG X Power Battery Replacement: step 2, image 1 of 2 LG X Power Battery Replacement: step 2, image 2 of 2
      • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
      Ask FixBot
    3. LG X Power Battery Replacement: step 3, image 1 of 2 LG X Power Battery Replacement: step 3, image 2 of 2
      • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
      • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
      Ask FixBot
    1. LG X Power Battery Replacement, Battery: step 4, image 1 of 3 LG X Power Battery Replacement, Battery: step 4, image 2 of 3 LG X Power Battery Replacement, Battery: step 4, image 3 of 3
      • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
      • Pull the cameras out to remove them.
      Ask FixBot
    2. LG X Power Battery Replacement: step 5, image 1 of 1
      • Use the flat end of a spudger to disconnect the battery from the motherboard.
      • You will not be removing anything, just disconnecting.
      Ask FixBot
    3. LG X Power Battery Replacement: step 6, image 1 of 1
      • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
      Ask FixBot
    4. LG X Power Battery Replacement: step 7, image 1 of 2 LG X Power Battery Replacement: step 7, image 2 of 2
      • Use a spudger and plastic opening tool to carefully pry up the battery.
      • There is a strong adhesive on the back of the battery that will make it difficult to remove.
      Ask FixBot
7 other people completed this guide.
Author
with
Chad Sears
1,200 Reputation
5 Guides authored
USF Tampa, Team S3-G6, Nance Spring 2018 Member of USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Members
72 Guides authored
5 Guide Comments
lg x power mobail sarkit board+ bettery kaha pe milegi
HASIBUL RAHAMAN - Reply Share
Were can i buy the battery?
Tasha Boost - Reply Share
thx for rundown
George Pryor - Reply Share
On my H700 Venture....only have to remove 3 screws on the charger port end of the phone to directly access the battery connection. No messing with cameras or motherboard moving. Be aware once you open phone it will no longer be waterproof. Battery from Amazon.
May not be worth the effort. Replace battery (twice) and all I get is a gray battery icon on the screen with a red flashing question mark when I hook up original equipment LG charger....for hours.
Bought a renewed H700 on Amazon, works great. My bad...I had not backed up my contact list from the phone internal storage...learned the hard way "internal" storage is not the SIM card. Anyone know how to recover contact list from a dead phone ? Contact me at heyinway@yahoo.com Thanks !
Ronald Fulton - Reply Share
Hey, great guide, thank you for going through the effort to document what it looks like.
It would have helped me to know where to insert the tool when removing the mid-frame -- I didn't know where to insert the tool or what the mid-frame will look like once it's on its way off the rest of the phone.
Best regards,
Yena
maktecfam - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 79
All Time: 21,241
