LG Watch Urbane Motherboard Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
77
All Time:
1,610
Comments: 5
5 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
In order to replace your motherboard you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, PH #000 screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the motherboard for the LG Watch Urbane.
Tools
    1. LG Watch Urbane Motherboard Replacement, Battery: step 1, image 1 of 2 LG Watch Urbane Motherboard Replacement, Battery: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Push on the band in order to expose the pins
      • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
      Ask FixBot
    2. LG Watch Urbane Motherboard Replacement: step 2, image 1 of 2 LG Watch Urbane Motherboard Replacement: step 2, image 2 of 2
      • Using plastic opening tools, carefully pry open the back cover of the the watch.
      • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
      Ask FixBot
    3. LG Watch Urbane Motherboard Replacement: step 3, image 1 of 3 LG Watch Urbane Motherboard Replacement: step 3, image 2 of 3 LG Watch Urbane Motherboard Replacement: step 3, image 3 of 3
      Magnetic Project Mat
      $19.95
      Buy
      • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
      • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
      • Using plastic opening tools, remove the four connectors attached to the motherboard
      Ask FixBot
    4. LG Watch Urbane Motherboard Replacement: step 4, image 1 of 3 LG Watch Urbane Motherboard Replacement: step 4, image 2 of 3 LG Watch Urbane Motherboard Replacement: step 4, image 3 of 3
      • Using the plastic opening tools, carefully lift up the motherboard.
      • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
      Ask FixBot
    1. LG Watch Urbane Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • And now you have your motherboard
      Ask FixBot
3 other people completed this guide.
Rey Diaz
720 Reputation
2 Guides authored
USF Tampa, Team 1-4, Remmell Fall 2015 Member of USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 77
All Time: 1,610
