Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓In order to replace your battery you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, 000PH screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the battery for the LG Watch Urbane.
Tools
Tool used on this step:Tweezers$4.99
Push on the band in order to expose the pins
Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
19 other people completed this guide.
12 Guide Comments
"pried" not "pryed"
The reassembly requires gluing the back together. How do you get the glue?
