Up to 20% off select tools
LG WM3050CW Temperature Sensor Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
98
All Time:
1,723
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the temperature sensor or thermistor in your LG WM3050CW washing machine.
The temperature sensor tells the washer what the water temperature is at. If your washer throws a "TE error", replacing this sensor may fix the issue. The temperature sensor is mounted near the bottom of the drum.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
    1. LG WM3050CW Temperature Sensor Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Temperature Sensor Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG WM3050CW Temperature Sensor Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
      Ask FixBot
    2. LG WM3050CW Temperature Sensor Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Temperature Sensor Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG WM3050CW Temperature Sensor Replacement: step 4, image 1 of 2 LG WM3050CW Temperature Sensor Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG WM3050CW Temperature Sensor Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG WM3050CW Temperature Sensor Replacement, Remove the detergent drawer: step 5, image 2 of 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Ask FixBot
    2. LG WM3050CW Temperature Sensor Replacement: step 6, image 1 of 3 LG WM3050CW Temperature Sensor Replacement: step 6, image 2 of 3 LG WM3050CW Temperature Sensor Replacement: step 6, image 3 of 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Ask FixBot
    1. LG WM3050CW Temperature Sensor Replacement, Disconnect the control panel: step 7, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Disconnect the control panel: step 7, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Disconnect the control panel: step 7, image 3 of 3
      • Disconnect the three harness connectors for the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG WM3050CW Temperature Sensor Replacement, Unfasten the control panel: step 8, image 1 of 2 LG WM3050CW Temperature Sensor Replacement, Unfasten the control panel: step 8, image 2 of 2
      • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
      Ask FixBot
    3. LG WM3050CW Temperature Sensor Replacement, Unfasten the detergent dispenser: step 9, image 1 of 1
      • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
      Ask FixBot
    4. LG WM3050CW Temperature Sensor Replacement, Unclip the control panel: step 10, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Unclip the control panel: step 10, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Unclip the control panel: step 10, image 3 of 3
      • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
      • Twist the screwdriver to release the clips securing the control panel.
      • Repeat this procedure for the remaining clips along the control panel.
      Ask FixBot
    5. LG WM3050CW Temperature Sensor Replacement, Remove the control panel: step 11, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the control panel: step 11, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the control panel: step 11, image 3 of 3
      • Lift the control panel upward to completely separate it from the chassis.
      • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
      • Remove the control panel.
      Ask FixBot
    1. LG WM3050CW Temperature Sensor Replacement, Open the door: step 12, image 1 of 2 LG WM3050CW Temperature Sensor Replacement, Open the door: step 12, image 2 of 2
      • Open the front door completely.
      Ask FixBot
    2. LG WM3050CW Temperature Sensor Replacement, Remove the boot ring: step 13, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the boot ring: step 13, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the boot ring: step 13, image 3 of 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Ask FixBot
    3. LG WM3050CW Temperature Sensor Replacement: step 14, image 1 of 3 LG WM3050CW Temperature Sensor Replacement: step 14, image 2 of 3 LG WM3050CW Temperature Sensor Replacement: step 14, image 3 of 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • This procedure will take significant force.
      Ask FixBot
    4. LG WM3050CW Temperature Sensor Replacement, Disconnect the boot: step 15, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Disconnect the boot: step 15, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Disconnect the boot: step 15, image 3 of 3
      • Use your fingers to pull the boot off its lip on the front panel.
      Ask FixBot
    5. LG WM3050CW Temperature Sensor Replacement: step 16, image 1 of 3 LG WM3050CW Temperature Sensor Replacement: step 16, image 2 of 3 LG WM3050CW Temperature Sensor Replacement: step 16, image 3 of 3
      • Work your fingers around the boot until its completely separated from the panel.
      Ask FixBot
    6. LG WM3050CW Temperature Sensor Replacement, Remove the filter panel: step 17, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the filter panel: step 17, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the filter panel: step 17, image 3 of 3
      • Open the filter panel at the bottom left of the front panel.
      • Twist the filter panel upward to unclip it from the front panel.
      Ask FixBot
    7. LG WM3050CW Temperature Sensor Replacement, Unfasten the filter trim: step 18, image 1 of 1
      • Use a Phillips driver to remove the two 12.8 mm‑long screws securing the filter trim.
      Ask FixBot
    8. LG WM3050CW Temperature Sensor Replacement, Remove the filter trim: step 19, image 1 of 2 LG WM3050CW Temperature Sensor Replacement, Remove the filter trim: step 19, image 2 of 2
      • Pull the filter trim straight off the front panel to remove it.
      Ask FixBot
    9. LG WM3050CW Temperature Sensor Replacement, Unfasten the lower front panel: step 20, image 1 of 1
      • Use a Phillips driver to remove the 12.8 mm-long screw securing the lower front panel.
      Ask FixBot
    10. LG WM3050CW Temperature Sensor Replacement, Unfasten the door latch: step 21, image 1 of 1
      • Use a Phillips driver to remove the two 16 mm‑long screws securing the door latch.
      Ask FixBot
    11. LG WM3050CW Temperature Sensor Replacement, Remove the door latch: step 22, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the door latch: step 22, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the door latch: step 22, image 3 of 3
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
      Ask FixBot
    12. LG WM3050CW Temperature Sensor Replacement, Unfasten the front panel: step 23, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Unfasten the front panel: step 23, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Unfasten the front panel: step 23, image 3 of 3
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Use a Phillips driver, or a 7 mm nut driver, to remove the six 15 mm‑long screws securing the front panel.
      Ask FixBot
    13. LG WM3050CW Temperature Sensor Replacement, Remove the front panel: step 24, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the front panel: step 24, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the front panel: step 24, image 3 of 3
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
      Ask FixBot
    14. LG WM3050CW Temperature Sensor Replacement: step 25, image 1 of 1
      • Remove the front panel.
      Ask FixBot
    1. LG WM3050CW Temperature Sensor Replacement, Disconnect the temperature sensor: step 26, image 1 of 2 LG WM3050CW Temperature Sensor Replacement, Disconnect the temperature sensor: step 26, image 2 of 2
      • Pull the temperature sensor connector downward to disconnect it.
      Ask FixBot
    2. LG WM3050CW Temperature Sensor Replacement, Cut the cable tie: step 27, image 1 of 2 LG WM3050CW Temperature Sensor Replacement, Cut the cable tie: step 27, image 2 of 2
      • Use angle cutters, or scissors, to cut the cable ties attaching the temperature sensor to the chassis.
      Ask FixBot
    3. LG WM3050CW Temperature Sensor Replacement, Remove the temperature sensor: step 28, image 1 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the temperature sensor: step 28, image 2 of 3 LG WM3050CW Temperature Sensor Replacement, Remove the temperature sensor: step 28, image 3 of 3
      • Pull the temperature sensor straight out of its slot in the chassis to remove it.
      • You may accidentally remove the rubber boot. Don't worry—just reinsert it with the temperature sensor during reassembly.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 98
All Time: 1,723
