LG WM3050CW Pump Hose Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
87
All Time:
647
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the pump hose in your LG WM3050CW Washing Machine.
The pump hose connects the tub to the drain pump. It's not the drain hose, which drains the wastewater out of the washer.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
    1. LG WM3050CW Pump Hose Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Pump Hose Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG WM3050CW Pump Hose Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Pump Hose Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Pump Hose Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
      Ask FixBot
    2. LG WM3050CW Pump Hose Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Pump Hose Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG WM3050CW Pump Hose Replacement: step 4, image 1 of 2 LG WM3050CW Pump Hose Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG WM3050CW Pump Hose Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG WM3050CW Pump Hose Replacement, Remove the detergent drawer: step 5, image 2 of 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Ask FixBot
    2. LG WM3050CW Pump Hose Replacement: step 6, image 1 of 3 LG WM3050CW Pump Hose Replacement: step 6, image 2 of 3 LG WM3050CW Pump Hose Replacement: step 6, image 3 of 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Ask FixBot
    1. LG WM3050CW Pump Hose Replacement, Disconnect the control panel: step 7, image 1 of 3 LG WM3050CW Pump Hose Replacement, Disconnect the control panel: step 7, image 2 of 3 LG WM3050CW Pump Hose Replacement, Disconnect the control panel: step 7, image 3 of 3
      • Disconnect the three harness connectors for the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG WM3050CW Pump Hose Replacement, Unfasten the control panel: step 8, image 1 of 2 LG WM3050CW Pump Hose Replacement, Unfasten the control panel: step 8, image 2 of 2
      • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
      Ask FixBot
    3. LG WM3050CW Pump Hose Replacement, Unfasten the detergent dispenser: step 9, image 1 of 1
      • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
      Ask FixBot
    4. LG WM3050CW Pump Hose Replacement, Unclip the control panel: step 10, image 1 of 3 LG WM3050CW Pump Hose Replacement, Unclip the control panel: step 10, image 2 of 3 LG WM3050CW Pump Hose Replacement, Unclip the control panel: step 10, image 3 of 3
      • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
      • Twist the screwdriver to release the clips securing the control panel.
      • Repeat this procedure for the remaining clips along the control panel.
      Ask FixBot
    5. LG WM3050CW Pump Hose Replacement, Remove the control panel: step 11, image 1 of 3 LG WM3050CW Pump Hose Replacement, Remove the control panel: step 11, image 2 of 3 LG WM3050CW Pump Hose Replacement, Remove the control panel: step 11, image 3 of 3
      • Lift the control panel upward to completely separate it from the chassis.
      • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
      • Remove the control panel.
      Ask FixBot
    1. LG WM3050CW Pump Hose Replacement, Open the door: step 12, image 1 of 2 LG WM3050CW Pump Hose Replacement, Open the door: step 12, image 2 of 2
      • Open the front door completely.
      Ask FixBot
    2. LG WM3050CW Pump Hose Replacement, Remove the boot ring: step 13, image 1 of 3 LG WM3050CW Pump Hose Replacement, Remove the boot ring: step 13, image 2 of 3 LG WM3050CW Pump Hose Replacement, Remove the boot ring: step 13, image 3 of 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Ask FixBot
    3. LG WM3050CW Pump Hose Replacement: step 14, image 1 of 3 LG WM3050CW Pump Hose Replacement: step 14, image 2 of 3 LG WM3050CW Pump Hose Replacement: step 14, image 3 of 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • This procedure will take significant force.
      Ask FixBot
    4. LG WM3050CW Pump Hose Replacement, Disconnect the boot: step 15, image 1 of 3 LG WM3050CW Pump Hose Replacement, Disconnect the boot: step 15, image 2 of 3 LG WM3050CW Pump Hose Replacement, Disconnect the boot: step 15, image 3 of 3
      • Use your fingers to pull the boot off its lip on the front panel.
      Ask FixBot
    5. LG WM3050CW Pump Hose Replacement: step 16, image 1 of 3 LG WM3050CW Pump Hose Replacement: step 16, image 2 of 3 LG WM3050CW Pump Hose Replacement: step 16, image 3 of 3
      • Work your fingers around the boot until its completely separated from the panel.
      Ask FixBot
    6. LG WM3050CW Pump Hose Replacement, Remove the filter panel: step 17, image 1 of 3 LG WM3050CW Pump Hose Replacement, Remove the filter panel: step 17, image 2 of 3 LG WM3050CW Pump Hose Replacement, Remove the filter panel: step 17, image 3 of 3
      • Open the filter panel at the bottom left of the front panel.
      • Twist the filter panel upward to unclip it from the front panel.
      Ask FixBot
    7. LG WM3050CW Pump Hose Replacement, Unfasten the filter trim: step 18, image 1 of 1
      • Use a Phillips driver to remove the two 12.8 mm‑long screws securing the filter trim.
      Ask FixBot
    8. LG WM3050CW Pump Hose Replacement, Remove the filter trim: step 19, image 1 of 2 LG WM3050CW Pump Hose Replacement, Remove the filter trim: step 19, image 2 of 2
      • Pull the filter trim straight off the front panel to remove it.
      Ask FixBot
    9. LG WM3050CW Pump Hose Replacement, Unfasten the lower front panel: step 20, image 1 of 1
      • Use a Phillips driver to remove the 12.8 mm-long screw securing the lower front panel.
      Ask FixBot
    10. LG WM3050CW Pump Hose Replacement, Unfasten the door latch: step 21, image 1 of 1
      • Use a Phillips driver to remove the two 16 mm‑long screws securing the door latch.
      Ask FixBot
    11. LG WM3050CW Pump Hose Replacement, Remove the door latch: step 22, image 1 of 3 LG WM3050CW Pump Hose Replacement, Remove the door latch: step 22, image 2 of 3 LG WM3050CW Pump Hose Replacement, Remove the door latch: step 22, image 3 of 3
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
      Ask FixBot
    12. LG WM3050CW Pump Hose Replacement, Unfasten the front panel: step 23, image 1 of 3 LG WM3050CW Pump Hose Replacement, Unfasten the front panel: step 23, image 2 of 3 LG WM3050CW Pump Hose Replacement, Unfasten the front panel: step 23, image 3 of 3
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Use a Phillips driver, or a 7 mm nut driver, to remove the six 15 mm‑long screws securing the front panel.
      Ask FixBot
    13. LG WM3050CW Pump Hose Replacement, Remove the front panel: step 24, image 1 of 3 LG WM3050CW Pump Hose Replacement, Remove the front panel: step 24, image 2 of 3 LG WM3050CW Pump Hose Replacement, Remove the front panel: step 24, image 3 of 3
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
      Ask FixBot
    14. LG WM3050CW Pump Hose Replacement: step 25, image 1 of 1
      • Remove the front panel.
      Ask FixBot
    1. LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: step 26, image 1 of 3 LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: step 26, image 2 of 3 LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: step 26, image 3 of 3
      • Use slip joint pliers to pinch the tub to pump hose clamp and pull it away from the assembly.
      • Pull the hose straight off the assembly to disconnect it.
      Ask FixBot
    1. LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: step 27, image 1 of 3 LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: step 27, image 2 of 3 LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: step 27, image 3 of 3
      • Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
      Ask FixBot
    2. LG WM3050CW Pump Hose Replacement, Remove the rear panel: step 28, image 1 of 3 LG WM3050CW Pump Hose Replacement, Remove the rear panel: step 28, image 2 of 3 LG WM3050CW Pump Hose Replacement, Remove the rear panel: step 28, image 3 of 3
      • Lift the rear panel upward to release its bottom clips.
      • Pull the rear panel away from the chassis to release the remaining clips.
      Ask FixBot
    3. LG WM3050CW Pump Hose Replacement: step 29, image 1 of 1
      • Remove the rear panel.
      Ask FixBot
    1. LG WM3050CW Pump Hose Replacement, Disconnect the air dome: step 30, image 1 of 2 LG WM3050CW Pump Hose Replacement, Disconnect the air dome: step 30, image 2 of 2
      • Pull the air dome hose straight up to disconnect it.
      Ask FixBot
    2. LG WM3050CW Pump Hose Replacement, Unfasten the air dome: step 31, image 1 of 1
      • Use a Phillips driver to remove the two 16.5 mm‑long screws securing the air dome.
      Ask FixBot
    3. LG WM3050CW Pump Hose Replacement: step 32, image 1 of 3 LG WM3050CW Pump Hose Replacement: step 32, image 2 of 3 LG WM3050CW Pump Hose Replacement: step 32, image 3 of 3
      • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
      Ask FixBot
    4. LG WM3050CW Pump Hose Replacement, Remove the air dome: step 33, image 1 of 3 LG WM3050CW Pump Hose Replacement, Remove the air dome: step 33, image 2 of 3 LG WM3050CW Pump Hose Replacement, Remove the air dome: step 33, image 3 of 3
      • Pull the air dome straight off its hose to remove it.
      • During reassembly, make sure the air dome nub is aligned properly with its slot in the hose.
      Ask FixBot
    1. LG WM3050CW Pump Hose Replacement, Loosen the pump hose: step 34, image 1 of 2 LG WM3050CW Pump Hose Replacement, Loosen the pump hose: step 34, image 2 of 2
      • Use a Phillips driver to loosen the pump hose from the drum enough to disconnect it.
      Ask FixBot
    2. LG WM3050CW Pump Hose Replacement, Disconnect the pump hose: step 35, image 1 of 2 LG WM3050CW Pump Hose Replacement, Disconnect the pump hose: step 35, image 2 of 2
      • Pull the pump hose straight off the drum to disconnect it.
      Ask FixBot
    3. LG WM3050CW Pump Hose Replacement, Remove the pump hose: step 36, image 1 of 1
      • Remove the pump hose.
      • During reassembly, use liquid laundry detergent to lubricate the hose around its tub connection.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 87
All Time: 647
