Up to 20% off select tools
LG WM3050CW Pressure Sensor Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
103
All Time:
1,440
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the pressure sensor in your LG WM3050CW Washing Machine.
The pressure sensor detects how much water is in the tub. The sensor LG uses in these washers have no moving parts, so it's unlikely to break. If the sensor malfunctions, the tub may under-fill or overfill.
    1. LG WM3050CW Pressure Sensor Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Pressure Sensor Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
      Ask FixBot
    2. LG WM3050CW Pressure Sensor Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Pressure Sensor Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG WM3050CW Pressure Sensor Replacement: step 4, image 1 of 2 LG WM3050CW Pressure Sensor Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG WM3050CW Pressure Sensor Replacement, Disconnect the pressure sensor: step 5, image 1 of 2 LG WM3050CW Pressure Sensor Replacement, Disconnect the pressure sensor: step 5, image 2 of 2
      • Disconnect the spade connector from the pressure sensor.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG WM3050CW Pressure Sensor Replacement: step 6, image 1 of 2 LG WM3050CW Pressure Sensor Replacement: step 6, image 2 of 2
      • Disconnect the hose from the pressure sensor.
      Ask FixBot
    3. LG WM3050CW Pressure Sensor Replacement, Unfasten the pressure sensor: step 7, image 1 of 1
      • Use a Phillips driver to remove the 16.5 mm-long screw securing the pressure sensor.
      Ask FixBot
    4. LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: step 8, image 1 of 3 LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: step 8, image 2 of 3 LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: step 8, image 3 of 3
      • Rotate the pressure sensor toward the left edge of the washing machine to unclip it from the main board cover.
      Ask FixBot
    5. LG WM3050CW Pressure Sensor Replacement: step 9, image 1 of 2 LG WM3050CW Pressure Sensor Replacement: step 9, image 2 of 2
      • Lift the pressure sensor away from its slot on the main board cover to remove it.
      • During reassembly, align the pressure sensor with the hole next to its slot before rotating it back into its original position.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 103
All Time: 1,440
