LG WM3050CW Main Board Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
89
All Time:
1,113
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the main board in your LG WM3050CW Washing Machine.
This is the main circuit board for the washer. It doesn't contain any buttons or dials—if your washer buttons or dials are broken, you'll need to replace the control panel instead.
Tools
    1. LG WM3050CW Main Board Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Main Board Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG WM3050CW Main Board Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Main Board Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Main Board Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
      Ask FixBot
    2. LG WM3050CW Main Board Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Main Board Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG WM3050CW Main Board Replacement: step 4, image 1 of 2 LG WM3050CW Main Board Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG WM3050CW Main Board Replacement, Disconnect the pressure sensor: step 5, image 1 of 2 LG WM3050CW Main Board Replacement, Disconnect the pressure sensor: step 5, image 2 of 2
      • Disconnect the spade connector from the pressure sensor.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG WM3050CW Main Board Replacement: step 6, image 1 of 2 LG WM3050CW Main Board Replacement: step 6, image 2 of 2
      • Disconnect the hose from the pressure sensor.
      Ask FixBot
    3. LG WM3050CW Main Board Replacement, Unfasten the pressure sensor: step 7, image 1 of 1
      • Use a Phillips driver to remove the 16.5 mm-long screw securing the pressure sensor.
      Ask FixBot
    4. LG WM3050CW Main Board Replacement, Remove the pressure sensor: step 8, image 1 of 3 LG WM3050CW Main Board Replacement, Remove the pressure sensor: step 8, image 2 of 3 LG WM3050CW Main Board Replacement, Remove the pressure sensor: step 8, image 3 of 3
      • Rotate the pressure sensor toward the left edge of the washing machine to unclip it from the main board cover.
      Ask FixBot
    5. LG WM3050CW Main Board Replacement: step 9, image 1 of 2 LG WM3050CW Main Board Replacement: step 9, image 2 of 2
      • Lift the pressure sensor away from its slot on the main board cover to remove it.
      • During reassembly, align the pressure sensor with the hole next to its slot before rotating it back into its original position.
      Ask FixBot
    1. LG WM3050CW Main Board Replacement, Unclip the control panel cable: step 10, image 1 of 3 LG WM3050CW Main Board Replacement, Unclip the control panel cable: step 10, image 2 of 3 LG WM3050CW Main Board Replacement, Unclip the control panel cable: step 10, image 3 of 3
      • Insert a flathead screwdriver between the chassis and the plastic clip securing the control panel cable.
      • Compress the clip and slide it out of the chassis to remove it.
      Ask FixBot
    2. LG WM3050CW Main Board Replacement: step 11, image 1 of 3 LG WM3050CW Main Board Replacement: step 11, image 2 of 3 LG WM3050CW Main Board Replacement: step 11, image 3 of 3
      • Use diagonal cutters, or scissors, to cut the cable tie securing the control panel cable to the main board cover.
      • Remove the pressure sensor hose from its clip in the main board cover.
      • During reassembly, replace the cable tie.
      Ask FixBot
    3. LG WM3050CW Main Board Replacement: step 12, image 1 of 3 LG WM3050CW Main Board Replacement: step 12, image 2 of 3 LG WM3050CW Main Board Replacement: step 12, image 3 of 3
      • Remove the twist tie bundling the cables at the top right of the main board cover.
      Ask FixBot
    4. LG WM3050CW Main Board Replacement, Remove the main board cover: step 13, image 1 of 3 LG WM3050CW Main Board Replacement, Remove the main board cover: step 13, image 2 of 3 LG WM3050CW Main Board Replacement, Remove the main board cover: step 13, image 3 of 3
      • Use a flathead screwdriver to disconnect the three plastic clips securing the top of the main board cover.
      • Pull the main board cover away from the chassis to disconnect the remaining clips on the side and bottom.
      • Remove the main board cover.
      Ask FixBot
    5. LG WM3050CW Main Board Replacement, Unfasten the main board: step 14, image 1 of 2 LG WM3050CW Main Board Replacement, Unfasten the main board: step 14, image 2 of 2
      • Use a Phillips driver to remove the 16.5 mm-long screw securing the main board to the back of the washer.
      Ask FixBot
    6. LG WM3050CW Main Board Replacement, Separate the main board from the chassis: step 15, image 1 of 3 LG WM3050CW Main Board Replacement, Separate the main board from the chassis: step 15, image 2 of 3 LG WM3050CW Main Board Replacement, Separate the main board from the chassis: step 15, image 3 of 3
      • Slide the main board toward the right edge of the device to disconnect the clips from their slots in the chassis.
      • Pull the main board toward the front of the device to completely separate the main board from the chassis.
      Ask FixBot
    7. LG WM3050CW Main Board Replacement, Remove the main board: step 16, image 1 of 3 LG WM3050CW Main Board Replacement, Remove the main board: step 16, image 2 of 3 LG WM3050CW Main Board Replacement, Remove the main board: step 16, image 3 of 3
      • Label each connector and its spot on the main board. During reassembly, reattach each connector to its proper spot.
      • Lift the main board out of the chassis slightly to access each of the connectors.
      • Disconnect each connector from the main board (eleven total).
      • Remove the main board.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 89
All Time: 1,113
