LG WM3050CW Electrical Noise Filter Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
97
All Time:
592
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the electrical noise filter in your LG WM3050CW Washing Machine.
This filter protects the washer's circuit boards from power surges and spikes. If your washer doesn't power on, this can be a common culprit.
Tools
    1. LG WM3050CW Electrical Noise Filter Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Electrical Noise Filter Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: step 2, image 1 of 3 LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: step 2, image 2 of 3 LG WM3050CW Electrical Noise Filter Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
      Ask FixBot
    2. LG WM3050CW Electrical Noise Filter Replacement, Remove the top panel: step 3, image 1 of 2 LG WM3050CW Electrical Noise Filter Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG WM3050CW Electrical Noise Filter Replacement: step 4, image 1 of 2 LG WM3050CW Electrical Noise Filter Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: step 5, image 1 of 3 LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: step 5, image 2 of 3 LG WM3050CW Electrical Noise Filter Replacement, Disconnect the noise filter: step 5, image 3 of 3
      • Disconnect the two spade connectors attached to the noise filter.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG WM3050CW Electrical Noise Filter Replacement, Unfasten the noise filter: step 6, image 1 of 1
      • Use a Phillips driver to remove the 12.5 mm-long screw securing the noise filter.
      Ask FixBot
    3. LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: step 7, image 1 of 3 LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: step 7, image 2 of 3 LG WM3050CW Electrical Noise Filter Replacement, Remove the noise filter: step 7, image 3 of 3
      • Slide the noise filter towards the front of the device to unclip it from the chassis.
      • Pull the filter downward to completely separate it from the device.
      • Remove the filter.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 97
All Time: 592
