LG WM3050CW Drain Filter Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
106
All Time:
1,104
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace or clean the drain filter in your LG WM3050CW Washing Machine.
The drain filter collects large debris, like loose change, that might be stuck to your clothes. If your washing machine isn't removing this debris, or if your tub is not draining properly, then your filter may be broken or clogged.
    1. LG WM3050CW Drain Filter Replacement, Unclip the filter door: step 1, image 1 of 2 LG WM3050CW Drain Filter Replacement, Unclip the filter door: step 1, image 2 of 2
      • Unclip the filter door from its slot in the chassis and let it rest on the ground.
      Ask FixBot
    2. LG WM3050CW Drain Filter Replacement, Drain the drain filter hose: step 2, image 1 of 3 LG WM3050CW Drain Filter Replacement, Drain the drain filter hose: step 2, image 2 of 3 LG WM3050CW Drain Filter Replacement, Drain the drain filter hose: step 2, image 3 of 3
      • Place a bowl next to the device.
      • Pull the drain filterhose out of its slot in the chassis enough to lay over the bowl.
      • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
      • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
      Ask FixBot
    3. LG WM3050CW Drain Filter Replacement, Remove the drain filter: step 3, image 1 of 3 LG WM3050CW Drain Filter Replacement, Remove the drain filter: step 3, image 2 of 3 LG WM3050CW Drain Filter Replacement, Remove the drain filter: step 3, image 3 of 3
      • Twist the drain filter counterclockwise until its fully disconnected from the chassis.
      • Remove the drain filter.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
250,853 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 106
All Time: 1,104
