Introduction
Go to step 1 ↓Use this guide to replace the detergent dispenser in your LG WM3050CW Washing Machine.
The detergent dispenser houses the detergent drawer. It has no moving parts and is unlikely to break.
Parts
Tools
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
Pull the detergent drawer away from the chassis as far as it will go.
Disconnect the three harness connectors for the control panel.
Use your hands to unclip the control panel cable from the detergent dispenser.
Insert a flathead screwdriver between the chassis and the plastic clip securing the control panel cable.
Compress the clip and slide it out of the chassis to remove it.
Move the cables out of the way of the detergent dispenser hoses before you continue.
To prevent confusion, label each hose and its corresponding dispenser connection.
Use a Phillips driver to loosen the screw securing the bellows to the detergent dispenser.
Pull the bellows straight off its connection on the dispenser to disconnect it.
Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
Slide the detergent dispenser toward the back of the device to unclip it from the chassis.
Pull the dispenser toward the left edge of the device to completely separate it from the chassis.
Repair didn’t go as planned? Ask our Answers community for help.
