LG WM3050CW Air Dome Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
92
All Time:
790
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the air dome in your LG WM3050CW Washing Machine.
The air dome helps regulate the water level inside the tub. If the dome is cracked, your washer may overflow.
Tools
    1. LG WM3050CW Air Dome Replacement, Safety Precautions: step 1, image 1 of 2 LG WM3050CW Air Dome Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG WM3050CW Air Dome Replacement, Unfasten the rear panel: step 2, image 1 of 3 LG WM3050CW Air Dome Replacement, Unfasten the rear panel: step 2, image 2 of 3 LG WM3050CW Air Dome Replacement, Unfasten the rear panel: step 2, image 3 of 3
      • Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
      Ask FixBot
    2. LG WM3050CW Air Dome Replacement, Remove the rear panel: step 3, image 1 of 3 LG WM3050CW Air Dome Replacement, Remove the rear panel: step 3, image 2 of 3 LG WM3050CW Air Dome Replacement, Remove the rear panel: step 3, image 3 of 3
      • Lift the rear panel upward to release its bottom clips.
      • Pull the rear panel away from the chassis to release the remaining clips.
      Ask FixBot
    3. LG WM3050CW Air Dome Replacement: step 4, image 1 of 1
      • Remove the rear panel.
      Ask FixBot
    1. LG WM3050CW Air Dome Replacement, Disconnect the air dome: step 5, image 1 of 2 LG WM3050CW Air Dome Replacement, Disconnect the air dome: step 5, image 2 of 2
      • Pull the air dome hose straight up to disconnect it.
      Ask FixBot
    2. LG WM3050CW Air Dome Replacement, Unfasten the air dome: step 6, image 1 of 1
      • Use a Phillips driver to remove the two 16.5 mm‑long screws securing the air dome.
      Ask FixBot
    3. LG WM3050CW Air Dome Replacement: step 7, image 1 of 3 LG WM3050CW Air Dome Replacement: step 7, image 2 of 3 LG WM3050CW Air Dome Replacement: step 7, image 3 of 3
      • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
      Ask FixBot
    4. LG WM3050CW Air Dome Replacement, Remove the air dome: step 8, image 1 of 3 LG WM3050CW Air Dome Replacement, Remove the air dome: step 8, image 2 of 3 LG WM3050CW Air Dome Replacement, Remove the air dome: step 8, image 3 of 3
      • Pull the air dome straight off its hose to remove it.
      • During reassembly, make sure the air dome nub is aligned properly with its slot in the hose.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 92
All Time: 790
