LG Vu CU920 Speaker Replacement
  1. LG Vu CU920 Speaker Replacement, Battery: step 1, image 1 of 3 LG Vu CU920 Speaker Replacement, Battery: step 1, image 2 of 3 LG Vu CU920 Speaker Replacement, Battery: step 1, image 3 of 3
    • Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
    Ask FixBot
  2. LG Vu CU920 Speaker Replacement: step 2, image 1 of 2 LG Vu CU920 Speaker Replacement: step 2, image 2 of 2
    • Remove the battery by placing your fingernail or an opening tool at the bottom edge of the battery and lift it out.
    Ask FixBot
  3. LG Vu CU920 Speaker Replacement, Motherboard: step 3, image 1 of 1
    • Remove the two 3.5 mm screws above the battery port with a Phillips #00 screwdriver.
    Ask FixBot
  4. LG Vu CU920 Speaker Replacement: step 4, image 1 of 2 LG Vu CU920 Speaker Replacement: step 4, image 2 of 2
    • Pull out the antenna to reveal a third screw.
    • Remove the 3.5 mm screw with a Phillips #00 screwdriver.
    Ask FixBot
  5. LG Vu CU920 Speaker Replacement: step 5, image 1 of 3 LG Vu CU920 Speaker Replacement: step 5, image 2 of 3 LG Vu CU920 Speaker Replacement: step 5, image 3 of 3
    • Using a plastic opening tool, gently pop up the plastic tab.
    • Use the plastic opening tool to pry up the edges of the plastic casing. You will then be able to slide it around the edge to dislodge it.
    Ask FixBot
  6. LG Vu CU920 Speaker Replacement: step 6, image 1 of 2 LG Vu CU920 Speaker Replacement: step 6, image 2 of 2
    • Remove the plastic case to reveal the motherboard.
    Ask FixBot
  7. LG Vu CU920 Speaker Replacement: step 7, image 1 of 1
    • Use a spudger to disconnect the cables from the motherboard.
    • The following steps will detail how to detach the cables from the connectors.
    Ask FixBot
  8. LG Vu CU920 Speaker Replacement: step 8, image 1 of 3 LG Vu CU920 Speaker Replacement: step 8, image 2 of 3 LG Vu CU920 Speaker Replacement: step 8, image 3 of 3
    • Gently lift the ZIF connector (black tab) holding the ribbon cable in place. When it is in the upright position, remove the cable from the back side.
    Ask FixBot
  9. LG Vu CU920 Speaker Replacement: step 9, image 1 of 1
    • Remove the jack attached to the red and blue wires by carefully pulling it upward from the motherboard.
    Ask FixBot
  10. LG Vu CU920 Speaker Replacement: step 10, image 1 of 1
    • Remove the round jack connected to the black cabel by carefully prying it up from beneath with a spudger or plastic opening tool.
    • This jack snaps on, so there will be more resistance than there was with the previous jack.
    Ask FixBot
  11. LG Vu CU920 Speaker Replacement: step 11, image 1 of 2 LG Vu CU920 Speaker Replacement: step 11, image 2 of 2
    • Remove the remaining three ribbon cables by gently lifting them by the ends, opposite of the cables, with a plastic opening tool or spudger until they pop out.
    Ask FixBot
  12. LG Vu CU920 Speaker Replacement: step 12, image 1 of 3 LG Vu CU920 Speaker Replacement: step 12, image 2 of 3 LG Vu CU920 Speaker Replacement: step 12, image 3 of 3
    • Remove the motherboard by gently prying it up with a spudger from the charging port.
    • Be careful not to yank the camera's ribbon cable as you lift the board. Make sure that it is in line with its hole in the motherboard.
    • Once the board has been lifted, remove it by pulling it away from the connected edge.
    Ask FixBot
  13. LG Vu CU920 Speaker Replacement, Bezel and External Casing: step 13, image 1 of 2 LG Vu CU920 Speaker Replacement, Bezel and External Casing: step 13, image 2 of 2
    • Remove the 3.5mm screw holding the antenna guide in place with a Philips #00 screwdriver.
    • Slide the antenna out to the edge, and remove the plastic tubing by gently pulling it out from the opposite end of the antenna.
    • This step can be done after the motherboard is removed, or before (as photographed).
    Ask FixBot
  14. LG Vu CU920 Speaker Replacement: step 14, image 1 of 2 LG Vu CU920 Speaker Replacement: step 14, image 2 of 2
    • Use a plastic opening tool to carefully pry up the metal antenna guide.
    Ask FixBot
  15. LG Vu CU920 Speaker Replacement: step 15, image 1 of 2 LG Vu CU920 Speaker Replacement: step 15, image 2 of 2
    • Using a Philips #00 screwdriver, remove the two 3.5mm screws on the bottom corners of the device.
    • Remove the single 3.5mm screw located at the top next to the speaker's ribbon cable.
    Ask FixBot
  16. LG Vu CU920 Speaker Replacement: step 16, image 1 of 3 LG Vu CU920 Speaker Replacement: step 16, image 2 of 3 LG Vu CU920 Speaker Replacement: step 16, image 3 of 3
    • Insert a plastic opening tool below the volume rocker and gently pry the silver casing up. As with the plastic casing over the motherboard, you should be able to slide the plastic opening tool along the edge to remove it.
    Ask FixBot
  17. LG Vu CU920 Speaker Replacement, Speaker: step 17, image 1 of 1
    • Locate the speaker on the inside of the plastic casing.
    • Use a plastic opening tool to pry the speaker out. It is attached with an adhesive.
    • Install a replacement speaker in place of the old one.
    Ask FixBot
Gregory Davis
51 Reputation
5 Guides authored
Cal Poly, Team 8-57, Johann Spring 2013 Member of Cal Poly, Team 8-57, Johann Spring 2013
CPSU-JOHANN-S13S8G57
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 506
