Up to 20% off select tools
LG Voyager Micro SD Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
4
Past 30 Days:
21
All Time:
701
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Tools
    1. LG Voyager Micro SD Replacement, Micro SD: step 1, image 1 of 1
      • Turn the phone onto its side so the label micro SD is facing upside down.
      • Once on its side, lift the micro SD cover up and swivel it away from the opening.
      Ask FixBot
    2. LG Voyager Micro SD Replacement: step 2, image 1 of 2 LG Voyager Micro SD Replacement: step 2, image 2 of 2
      • The Micro SD card will appear as a thin plastic piece sticking out of the phone
      • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
      • The card should be sticking out of the phone slightly once this is done.
      • Remove the card from the slot
      Ask FixBot
Author
with
Michelle
20 Reputation
2 Guides authored
Cal Poly, Team 17-26, Amido Spring 2012 Member of Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 21
All Time: 701
