Up to 20% off select tools
LG Voyager Keyboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
18
All Time:
802
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Difficult
Tools
    1. LG Voyager Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn over the phone so the front screen is facing down and the back side is up.
      Ask FixBot
    2. LG Voyager Keyboard Replacement: step 2, image 1 of 1
      • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
      Ask FixBot
    3. LG Voyager Keyboard Replacement: step 3, image 1 of 1
      • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
      • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
      • Then press down on the bottom of the battery and it should snap into place
      Ask FixBot
    1. LG Voyager Keyboard Replacement, Keyboard: step 4, image 1 of 2 LG Voyager Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
      Ask FixBot
    2. LG Voyager Keyboard Replacement: step 5, image 1 of 2 LG Voyager Keyboard Replacement: step 5, image 2 of 2
      • Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
      Ask FixBot
    3. LG Voyager Keyboard Replacement: step 6, image 1 of 2 LG Voyager Keyboard Replacement: step 6, image 2 of 2
      • Now pry open the back of the phone.
      • Make sure that you use the plastic opening tool to go around the entire phone to help open the phone.
      Ask FixBot
    4. LG Voyager Keyboard Replacement: step 7, image 1 of 2 LG Voyager Keyboard Replacement: step 7, image 2 of 2
      • Carefully separate the keyboard from the top of the phone.
      • Be careful not to break the ribbon cable.
      Ask FixBot
    5. LG Voyager Keyboard Replacement: step 8, image 1 of 1
      • Detach the keyboard from the phone by taking off the little metal latches.
      • When replacing the old keyboard with a new one you will have to solder the metal latches to the new board.
      Ask FixBot
Author
with
Lance Collins
7 Reputation
1 Guide authored
Cal Poly, Team 17-26, Amido Spring 2012 Member of Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 802
