Up to 20% off select tools
LG Volt Power Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
106
All Time:
922
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The power button for the LG Volt is located at the right side of the device. Use this guide to replace the button of the LG Volt.
    1. LG Volt Power Button Replacement, Power Button: step 1, image 1 of 3 LG Volt Power Button Replacement, Power Button: step 1, image 2 of 3 LG Volt Power Button Replacement, Power Button: step 1, image 3 of 3
      • Pry back cover with finger in the crease.
      • Remove back casing.
      Ask FixBot
    2. LG Volt Power Button Replacement: step 2, image 1 of 3 LG Volt Power Button Replacement: step 2, image 2 of 3 LG Volt Power Button Replacement: step 2, image 3 of 3
      • With your finger, pry the battery out through the crease made for removal.
      Ask FixBot
    3. LG Volt Power Button Replacement: step 3, image 1 of 3 LG Volt Power Button Replacement: step 3, image 2 of 3 LG Volt Power Button Replacement: step 3, image 3 of 3
      • Remove all 11 (4mm) screws with the JIS #000 screwdriver
      • There are three screws on top, three above the battery, one next to the battery, one under the battery and three at the bottom of the phone.
      Ask FixBot
    4. LG Volt Power Button Replacement: step 4, image 1 of 3 LG Volt Power Button Replacement: step 4, image 2 of 3 LG Volt Power Button Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to remove the back housing from the frame of the phone.
      Ask FixBot
    5. LG Volt Power Button Replacement: step 5, image 1 of 3 LG Volt Power Button Replacement: step 5, image 2 of 3 LG Volt Power Button Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Use the precision tweezers set to gently lift the rubber tab off its anchor.
      • Then push the power button through the cutout to remove completely.
      Ask FixBot
Author
with
Adrian Soldan
464 Reputation
4 Guides authored
USF Tampa, Team S3-G3, Cannon Fall 2017 Member of USF Tampa, Team S3-G3, Cannon Fall 2017
USFT-CANNON-F17S3G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 106
All Time: 922
