LG Volt LS740 Charging Port Replacement
    1. LG Volt LS740 Charging Port Replacement, Power off and Unplug Phone: step 1, image 1 of 2 LG Volt LS740 Charging Port Replacement, Power off and Unplug Phone: step 1, image 2 of 2
      • Always power off and unplug your devices before servicing them.
      Ask FixBot
    2. LG Volt LS740 Charging Port Replacement, Remove Rear Cover: step 2, image 1 of 1
      • There is a pry tab you can use your fingernail or a pry tool to remove the rear cover.
      Ask FixBot
    3. LG Volt LS740 Charging Port Replacement, Remove Battery & Sim Card: step 3, image 1 of 2 LG Volt LS740 Charging Port Replacement, Remove Battery & Sim Card: step 3, image 2 of 2
      • Note the location of the screws to remove the inner rear panel.
      Ask FixBot
    4. LG Volt LS740 Charging Port Replacement, Remove Inner Rear Cover: step 4, image 1 of 2 LG Volt LS740 Charging Port Replacement, Remove Inner Rear Cover: step 4, image 2 of 2
      • Remove the 11 screws on the inside rear cover using your Phillips screw driver.
      • See photo from "Remove Battery" step for location of screws.
      • Use your pry tool and carefully work your way around the inside rear cover to undo the snaps and remove it.
      Ask FixBot
    5. LG Volt LS740 Charging Port Replacement, Remove Charing Port / Daughter Board: step 5, image 1 of 1
      • Disconnect the 3 cables and two screws before attempting to remove the charging port circuitry.
      • Beware the adhesive on the back!
      Ask FixBot
2 other people completed this guide.
SMcC21985
1,271 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 110
All Time: 876
