LG VX9800 LCD Screens Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
0
Past 7 Days:
9
Past 30 Days:
41
All Time:
2,697
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 9 - 25 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
The LCD screens are connected as one unit, and therefore should be removed together.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. LG VX9800 LCD Screens Replacement, Front Keypad: step 1, image 1 of 1
      • Remove the two triangular pads at the top of the two speakers.
      • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
      Ask FixBot
    2. LG VX9800 LCD Screens Replacement: step 2, image 1 of 1
      • Remove the two rubber cylinders from their shafts. These cover more screws.
      • This requires a little more effort, so you may need to "dig" them out.
      Ask FixBot
    3. LG VX9800 LCD Screens Replacement: step 3, image 1 of 1
      • Now remove the four screws.
      • The screws are small, so put them somewhere that you can easily keep track of them.
      Ask FixBot
    4. LG VX9800 LCD Screens Replacement: step 4, image 1 of 1
      • Starting on the side with red square, pry the faceplate upwards with the flat end of a spudger.
      • Continue to slide the flat edge along the seam of the faceplate.
      • You should hear popping or snapping noises as the faceplate is being removed.
      Ask FixBot
    5. LG VX9800 LCD Screens Replacement: step 5, image 1 of 2 LG VX9800 LCD Screens Replacement: step 5, image 2 of 2
      • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
      • Lift the dislodged faceplate off the motherboard while being mindful of the wires still attached to it.
      Ask FixBot
    6. LG VX9800 LCD Screens Replacement: step 6, image 1 of 3 LG VX9800 LCD Screens Replacement: step 6, image 2 of 3 LG VX9800 LCD Screens Replacement: step 6, image 3 of 3
      • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
      • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
      • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
      Ask FixBot
    7. LG VX9800 LCD Screens Replacement: step 7, image 1 of 1
      • The faceplate and keypad can now be completely removed from the phone.
      Ask FixBot
    1. LG VX9800 LCD Screens Replacement, LCD Screens: step 8, image 1 of 3 LG VX9800 LCD Screens Replacement, LCD Screens: step 8, image 2 of 3 LG VX9800 LCD Screens Replacement, LCD Screens: step 8, image 3 of 3
      • Wedge the spudger into the small gap between the phone and the metal casing of the motherboard.
      • Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise.
      • There is a ribbon at the end of this groove, do not slide the spudger into the ribbon.
      • Now use the spudger to lift the other side of the motherboard.
      Ask FixBot
    2. LG VX9800 LCD Screens Replacement: step 9, image 1 of 1
      • Lift the motherboard at an angle.
      • Do not completely remove the motherboard. Doing so will tear the ribbon!
      Ask FixBot
    3. LG VX9800 LCD Screens Replacement: step 10, image 1 of 2 LG VX9800 LCD Screens Replacement: step 10, image 2 of 2
      • Gently pull the LCD screen upwards.
      • It can be tricky do this, you may want to use a spudger to pry it up if it doesn't pull up easily.
      • Remove the speaker wires from the LCD screen.
      • Replace the LCD screen and solder the wires to the new screen.
      • This step requires soldering. Only do this step if you are OK with soldering small wires. Look at this guide for help with soldering.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Aaron Rowley
33 Reputation
2 Guides authored
Cal Poly, Team 16-32, Maness Winter 2010 Member of Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 2,697
