Up to 20% off select tools
LG VX9800 Front Keypad Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
5
Past 30 Days:
22
All Time:
2,429
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Very easy
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The front keypad suffers a lot of wear-and-tear, but can be easily replaced. This guide will show you how to remove the old keypad so that you may install a new one.
    1. LG VX9800 Front Keypad Replacement, Front Keypad: step 1, image 1 of 1
      • Remove the two triangular pads at the top of the two speakers.
      • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
      Ask FixBot
    2. LG VX9800 Front Keypad Replacement: step 2, image 1 of 1
      • Remove the two rubber cylinders from their shafts. These cover more screws.
      • This requires a little more effort, so you may need to "dig" them out.
      Ask FixBot
    3. LG VX9800 Front Keypad Replacement: step 3, image 1 of 1
      • Now remove the four screws.
      • The screws are small, so put them somewhere that you can easily keep track of them.
      Ask FixBot
    4. LG VX9800 Front Keypad Replacement: step 4, image 1 of 1
      • Starting on the side with red square, pry the faceplate upwards with the flat end of a spudger.
      • Continue to slide the flat edge along the seam of the faceplate.
      • You should hear popping or snapping noises as the faceplate is being removed.
      Ask FixBot
    5. LG VX9800 Front Keypad Replacement: step 5, image 1 of 2 LG VX9800 Front Keypad Replacement: step 5, image 2 of 2
      • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
      • Lift the dislodged faceplate off the motherboard while being mindful of the wires still attached to it.
      Ask FixBot
    6. LG VX9800 Front Keypad Replacement: step 6, image 1 of 3 LG VX9800 Front Keypad Replacement: step 6, image 2 of 3 LG VX9800 Front Keypad Replacement: step 6, image 3 of 3
      • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
      • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
      • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
      Ask FixBot
    7. LG VX9800 Front Keypad Replacement: step 7, image 1 of 1
      • The faceplate and keypad can now be completely removed from the phone.
      Ask FixBot
Finish Line
Author
with
Aaron Rowley
33 Reputation
2 Guides authored
Cal Poly, Team 16-32, Maness Winter 2010 Member of Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 22
All Time: 2,429
