LG VX8700 Motherboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
86
All Time:
1,875
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
    1. LG VX8700 Motherboard Replacement, Battery: step 1, image 1 of 2 LG VX8700 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Power the phone off.
      • Slide the back cover off using the release latch with your fingers to expose the battery.
      Ask FixBot
    2. LG VX8700 Motherboard Replacement: step 2, image 1 of 2 LG VX8700 Motherboard Replacement: step 2, image 2 of 2
      • Lift one side of the battery using a plastic opening tool or your fingers.
      • Carefully remove the battery and set it aside.
      • When installing the new battery, align the metal pins with those of the phone.
      Ask FixBot
    1. LG VX8700 Motherboard Replacement, Keypad: step 3, image 1 of 2 LG VX8700 Motherboard Replacement, Keypad: step 3, image 2 of 2
      • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
      Ask FixBot
    2. LG VX8700 Motherboard Replacement: step 4, image 1 of 2 LG VX8700 Motherboard Replacement: step 4, image 2 of 2
      • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
      • Slide the opening tool along the seam and around the edge of the phone to separate the case.
      Ask FixBot
    3. LG VX8700 Motherboard Replacement: step 5, image 1 of 1
      • Separate the two halves of the phone.
      • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
      • The plastic casing is displayed on the right.
      Ask FixBot
    4. LG VX8700 Motherboard Replacement: step 6, image 1 of 3 LG VX8700 Motherboard Replacement: step 6, image 2 of 3 LG VX8700 Motherboard Replacement: step 6, image 3 of 3
      • Hold the phone casing with one hand and the keypad assembly with the other.
      • Separate the phone casing from the keypad/motherboard.
      Ask FixBot
    5. LG VX8700 Motherboard Replacement: step 7, image 1 of 2 LG VX8700 Motherboard Replacement: step 7, image 2 of 2
      • Pull the two boards apart to separate the keypad from the motherboard.
      Ask FixBot
    1. LG VX8700 Motherboard Replacement, Motherboard: step 8, image 1 of 1
      • First, pull back the tape covering the connection between the motherboard and the ribbon cable.
      • Separate the connection, using the plastic opening tool.
      Ask FixBot
    2. LG VX8700 Motherboard Replacement: step 9, image 1 of 2 LG VX8700 Motherboard Replacement: step 9, image 2 of 2
      • After the connection is removed, the motherboard is successfully removed.
      Ask FixBot
Stanley Thomas
41 Reputation
4 Guides authored
Cal Poly, Team 8-16, Maness Winter 2012 Member of Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 86
All Time: 1,875
