Up to 20% off select tools
LG VX8700 LCD Screen Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
24
Past 30 Days:
105
All Time:
2,412
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace your LG VX8700 LCD screen if your screen is black after turning the phone on. A black screen may be caused because of a faulty LCD screen. This replacement may also be needed if your screen is cracked.
The LCD screen is used to display information on the phone.
Before using this guide, completely charge the battery. If this does not work, turn the phone off while charging the battery, then turn the phone back on. If this battery charging technique does not work, you may need to replace the screen.
Soldering skills are required to complete this replacement.
For additional information about this device, visit this page: LG VX8700 LCD User Manual.
    1. LG VX8700 LCD Screen Replacement, Battery: step 1, image 1 of 2 LG VX8700 LCD Screen Replacement, Battery: step 1, image 2 of 2
      • Power the phone off.
      • Slide the back cover off using the release latch with your fingers to expose the battery.
      Ask FixBot
    2. LG VX8700 LCD Screen Replacement: step 2, image 1 of 2 LG VX8700 LCD Screen Replacement: step 2, image 2 of 2
      • Lift one side of the battery using a plastic opening tool or your fingers.
      • Carefully remove the battery and set it aside.
      • When installing the new battery, align the metal pins with those of the phone.
      Ask FixBot
    1. LG VX8700 LCD Screen Replacement, Front Bezel: step 3, image 1 of 1
      • Turn your phone around and open the flip phone. The screen is now facing you.
      • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
      • Remove the two grey screw-covers.
      Ask FixBot
    2. LG VX8700 LCD Screen Replacement: step 4, image 1 of 2 LG VX8700 LCD Screen Replacement: step 4, image 2 of 2
      • Use the ejection tab at the top to remove the screen.
      • There is a gap between the case and the screen near the ear piece.
      • Insert the plastic opening tool in the gap and pry up the screen.
      • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
      Ask FixBot
    3. LG VX8700 LCD Screen Replacement: step 5, image 1 of 1
      • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
      Ask FixBot
    4. LG VX8700 LCD Screen Replacement: step 6, image 1 of 2 LG VX8700 LCD Screen Replacement: step 6, image 2 of 2
      • Turn your phone around. The battery side will be facing you.
      • Insert the plastic opening tool into the groove to remove the top cover of the phone.
      • Carefully open the cover.
      Ask FixBot
    1. LG VX8700 LCD Screen Replacement, Ear Piece: step 7, image 1 of 1
      • Locate the earpiece, which is the black component at the top with black and red wires.
      • Remove the component. Using a soldering iron, desolder the top ear piece.
      Ask FixBot
    2. LG VX8700 LCD Screen Replacement: step 8, image 1 of 2 LG VX8700 LCD Screen Replacement: step 8, image 2 of 2
      • Using the plastic opening tool, lift the earpiece to remove it from the phone.
      Ask FixBot
    1. LG VX8700 LCD Screen Replacement, LCD Screen: step 9, image 1 of 1
      • Using a soldering iron, desolder the wires connected to the LCD board.
      Ask FixBot
    2. LG VX8700 LCD Screen Replacement: step 10, image 1 of 1
      • Using the plastic opening tool, carefully disconnect the ribbon connecting the two pieces.
      Ask FixBot
    3. LG VX8700 LCD Screen Replacement: step 11, image 1 of 1
      • Remove the LCD screen.
      Ask FixBot
2 other people completed this guide.
Author
with
Stanley Thomas
41 Reputation
4 Guides authored
Cal Poly, Team 8-16, Maness Winter 2012 Member of Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 105
All Time: 2,412
