LG VX8700 Ear Piece Replacement
    1. LG VX8700 Ear Piece Replacement, Battery: step 1, image 1 of 2 LG VX8700 Ear Piece Replacement, Battery: step 1, image 2 of 2
      • Power the phone off.
      • Slide the back cover off using the release latch with your fingers to expose the battery.
      Ask FixBot
    2. LG VX8700 Ear Piece Replacement: step 2, image 1 of 2 LG VX8700 Ear Piece Replacement: step 2, image 2 of 2
      • Lift one side of the battery using a plastic opening tool or your fingers.
      • Carefully remove the battery and set it aside.
      • When installing the new battery, align the metal pins with those of the phone.
      Ask FixBot
    1. LG VX8700 Ear Piece Replacement, Front Bezel: step 3, image 1 of 1
      • Turn your phone around and open the flip phone. The screen is now facing you.
      • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
      • Remove the two grey screw-covers.
      Ask FixBot
    2. LG VX8700 Ear Piece Replacement: step 4, image 1 of 2 LG VX8700 Ear Piece Replacement: step 4, image 2 of 2
      • Use the ejection tab at the top to remove the screen.
      • There is a gap between the case and the screen near the ear piece.
      • Insert the plastic opening tool in the gap and pry up the screen.
      • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
      Ask FixBot
    3. LG VX8700 Ear Piece Replacement: step 5, image 1 of 1
      • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
      Ask FixBot
    4. LG VX8700 Ear Piece Replacement: step 6, image 1 of 2 LG VX8700 Ear Piece Replacement: step 6, image 2 of 2
      • Turn your phone around. The battery side will be facing you.
      • Insert the plastic opening tool into the groove to remove the top cover of the phone.
      • Carefully open the cover.
      Ask FixBot
    1. LG VX8700 Ear Piece Replacement, Ear Piece: step 7, image 1 of 1
      • Locate the earpiece, which is the black component at the top with black and red wires.
      • Remove the component. Using a soldering iron, desolder the top ear piece.
      Ask FixBot
    2. LG VX8700 Ear Piece Replacement: step 8, image 1 of 2 LG VX8700 Ear Piece Replacement: step 8, image 2 of 2
      • Using the plastic opening tool, lift the earpiece to remove it from the phone.
      Ask FixBot
Stanley Thomas
41 Reputation
4 Guides authored
Cal Poly, Team 8-16, Maness Winter 2012 Member of Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 1,387
