Up to 20% off select tools
LG VX8550 Screen Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
85
All Time:
4,677
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
Steps to remove LG VX8550 screen
    1. LG VX8550 Screen Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release up.
      Ask FixBot
    2. LG VX8550 Screen Replacement: step 2, image 1 of 1
      • Remove the battery by lifting away from the case.
      Ask FixBot
    1. LG VX8550 Screen Replacement, Case: step 3, image 1 of 1
      • Remove the 2 screw covers next to the rear speaker with a Push Pin.
      Ask FixBot
    2. LG VX8550 Screen Replacement: step 4, image 1 of 1
      • Remove the 4 cover screws with a Philips #00 screwdriver.
      Ask FixBot
    3. LG VX8550 Screen Replacement: step 5, image 1 of 1
      • Use the iPod opening tool to pry off the back casing.
      Ask FixBot
    4. LG VX8550 Screen Replacement: step 6, image 1 of 1
      • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
      Ask FixBot
    5. LG VX8550 Screen Replacement: step 7, image 1 of 1
      • Separate the casing halves.
      • Be sure to keep track of the side buttons as they fall out.
      Ask FixBot
    1. LG VX8550 Screen Replacement, Motherboard: step 8, image 1 of 1
      • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
      Ask FixBot
    2. LG VX8550 Screen Replacement: step 9, image 1 of 1
      • Carefully lift up on the motherboard to see the ribbon cables underneath.
      • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
      Ask FixBot
    3. LG VX8550 Screen Replacement: step 10, image 1 of 1
      • Remove the motherboard from the front casing by lifting straight up.
      Ask FixBot
    1. LG VX8550 Screen Replacement, Keypad Housing: step 11, image 1 of 1
      • Lay the phone with the screen facedown.
      • The 6 slider screws are visible.
      Ask FixBot
    2. LG VX8550 Screen Replacement: step 12, image 1 of 1
      • Peel back but don't remove the blue tape to access the 2 center screws.
      • Remove the 6 slider screws with the Phillips #00 screwdriver.
      Ask FixBot
    3. LG VX8550 Screen Replacement: step 13, image 1 of 1
      • Lift the keypad housing away from the slider.
      Ask FixBot
    1. LG VX8550 Screen Replacement, Front Case: step 14, image 1 of 1
      • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
      Ask FixBot
    2. LG VX8550 Screen Replacement: step 15, image 1 of 1
      • Remove the 6 screws with a Phillips #00 Screwdriver.
      Ask FixBot
    3. LG VX8550 Screen Replacement: step 16, image 1 of 1
      • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
      Ask FixBot
    4. LG VX8550 Screen Replacement: step 17, image 1 of 1
      • Carefully lift the slider mechanism to see the ribbon cables underneath.
      Ask FixBot
    5. LG VX8550 Screen Replacement: step 18, image 1 of 1
      • Slide ribbon cable through the slider mechanism.
      Ask FixBot
    6. LG VX8550 Screen Replacement: step 19, image 1 of 1
      • Separate the two halves.
      Ask FixBot
    1. LG VX8550 Screen Replacement, Screen: step 20, image 1 of 1
      • With the spudger, lift up under the connector to unplug it from the circuit board.
      Ask FixBot
    2. LG VX8550 Screen Replacement: step 21, image 1 of 1
      • Lift and remove the blue tape from screen connector.
      Ask FixBot
    3. LG VX8550 Screen Replacement: step 22, image 1 of 1
      • Lift the top edge of the screen using a pin to pry under the corner.
      Ask FixBot
    4. LG VX8550 Screen Replacement: step 23, image 1 of 1
      • Grasp the ribbon cable near the connector and carefully slide it out of the white connector.
      • It is helpful to gently wiggle the ribbon cable from side to side.
      Ask FixBot
2 other people completed this guide.
Author
with
Nathan Jones
89 Reputation
10 Guides authored
Cal Poly, Team 34-55, Forte Spring 2010 Member of Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Members
120 Guides authored
1 Guide Comment
What’s the process if I just need to replace the flex cable not the whole screen?
Roll Sumthin - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 85
All Time: 4,677
