LG VX8550 Keypad Housing Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
87
All Time:
2,411
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
Steps to remove LG VX8550 keypad housing
Tools
    1. LG VX8550 Keypad Housing Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release up.
      Ask FixBot
    2. LG VX8550 Keypad Housing Replacement: step 2, image 1 of 1
      • Remove the battery by lifting away from the case.
      Ask FixBot
    1. LG VX8550 Keypad Housing Replacement, Case: step 3, image 1 of 1
      • Remove the 2 screw covers next to the rear speaker with a Push Pin.
      Ask FixBot
    2. LG VX8550 Keypad Housing Replacement: step 4, image 1 of 1
      • Remove the 4 cover screws with a Philips #00 screwdriver.
      Ask FixBot
    3. LG VX8550 Keypad Housing Replacement: step 5, image 1 of 1
      • Use the iPod opening tool to pry off the back casing.
      Ask FixBot
    4. LG VX8550 Keypad Housing Replacement: step 6, image 1 of 1
      • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
      Ask FixBot
    5. LG VX8550 Keypad Housing Replacement: step 7, image 1 of 1
      • Separate the casing halves.
      • Be sure to keep track of the side buttons as they fall out.
      Ask FixBot
    1. LG VX8550 Keypad Housing Replacement, Motherboard: step 8, image 1 of 1
      • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
      Ask FixBot
    2. LG VX8550 Keypad Housing Replacement: step 9, image 1 of 1
      • Carefully lift up on the motherboard to see the ribbon cables underneath.
      • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
      Ask FixBot
    3. LG VX8550 Keypad Housing Replacement: step 10, image 1 of 1
      • Remove the motherboard from the front casing by lifting straight up.
      Ask FixBot
    1. LG VX8550 Keypad Housing Replacement, Keypad Housing: step 11, image 1 of 1
      • Lay the phone with the screen facedown.
      • The 6 slider screws are visible.
      Ask FixBot
    2. LG VX8550 Keypad Housing Replacement: step 12, image 1 of 1
      • Peel back but don't remove the blue tape to access the 2 center screws.
      • Remove the 6 slider screws with the Phillips #00 screwdriver.
      Ask FixBot
    3. LG VX8550 Keypad Housing Replacement: step 13, image 1 of 1
      • Lift the keypad housing away from the slider.
      Ask FixBot
Nathan Jones
89 Reputation
10 Guides authored
Cal Poly, Team 34-55, Forte Spring 2010 Member of Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 87
All Time: 2,411
