Up to 20% off select tools
LG VX8350R Keypad Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
87
All Time:
1,083
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide illustrates how to replace the keypad on the LG VX8350R.
    1. LG VX8350R Keypad Replacement, Keypad: step 1, image 1 of 3 LG VX8350R Keypad Replacement, Keypad: step 1, image 2 of 3 LG VX8350R Keypad Replacement, Keypad: step 1, image 3 of 3
      • Using your thumb, slide battery cover off in a downward direction.
      Ask FixBot
    2. LG VX8350R Keypad Replacement: step 2, image 1 of 2 LG VX8350R Keypad Replacement: step 2, image 2 of 2
      • Place the plastic opening tool at the top of the battery and pry it out to remove. Set the battery aside.
      Ask FixBot
    3. LG VX8350R Keypad Replacement: step 3, image 1 of 1
      • With a Phillips #00 Screwdriver, remove the four screws in a counter-clockwise direction from the back cover. Set them aside on a surface where they won't roll away; these screws will be used in reassembly.
      Ask FixBot
    4. LG VX8350R Keypad Replacement: step 4, image 1 of 3 LG VX8350R Keypad Replacement: step 4, image 2 of 3 LG VX8350R Keypad Replacement: step 4, image 3 of 3
      • Using the plastic opening tool, carefully pry off the back cover. You may need to use the opening tool around the entire edge of the back cover to remove completely.
      • You will have to use some force to remove the upper part of the back cover. Apply enough force to separate the pieces without cracking the back cover.
      Ask FixBot
    5. LG VX8350R Keypad Replacement: step 5, image 1 of 2 LG VX8350R Keypad Replacement: step 5, image 2 of 2
      • Gently lift the green computer chip plate out of the way to expose the keypad.
      • The green computer chip plate cannot be completely removed. It is attached to the phone by a ribbon. Be careful not to break this ribbon when moving the green computer chip plate.
      Ask FixBot
    6. LG VX8350R Keypad Replacement: step 6, image 1 of 3 LG VX8350R Keypad Replacement: step 6, image 2 of 3 LG VX8350R Keypad Replacement: step 6, image 3 of 3
      • Remove the keypad using your fingers and set aside.
      Ask FixBot
    7. LG VX8350R Keypad Replacement: step 7, image 1 of 3 LG VX8350R Keypad Replacement: step 7, image 2 of 3 LG VX8350R Keypad Replacement: step 7, image 3 of 3
      • Align the small holes in the new keypad with the posts on the phone.
      Ask FixBot
    8. LG VX8350R Keypad Replacement: step 8, image 1 of 3 LG VX8350R Keypad Replacement: step 8, image 2 of 3 LG VX8350R Keypad Replacement: step 8, image 3 of 3
      • When replacing the computer chip, the sensor bar for the volume button may pop out of place. If this occurs, gently push the bars back into place behind the buttons with your fingers.
      Ask FixBot
Author
with
Alex Goots
117 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 87
All Time: 1,083
