Up to 20% off select tools
LG VX7000 Keypad Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
25
All Time:
1,487
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Tools
Introduction
Go to step 1 ↓
Replace damaged keypad.
    1. LG VX7000 Keypad Replacement, Battery: step 1, image 1 of 1
      • Lay the phone, screen side down, in your palm.
      • Slide the grey button towards the top of the phone.
      Ask FixBot
    2. LG VX7000 Keypad Replacement: step 2, image 1 of 1
      • With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
      Ask FixBot
    1. LG VX7000 Keypad Replacement, Keypad: step 3, image 1 of 1
      • Locate four screws underneath of the battery.
      • Remove screws by turning counter clockwise with screwdriver until they pop out.
      Ask FixBot
    2. LG VX7000 Keypad Replacement: step 4, image 1 of 1
      • Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
      • Note: There will be a significant amount of resistance.
      Ask FixBot
    3. LG VX7000 Keypad Replacement: step 5, image 1 of 1
      • Lift up logic board without completely removing from phone.
      • Remove entire keypad from beneath the logic board.
      Ask FixBot
    4. LG VX7000 Keypad Replacement: step 6, image 1 of 1
      • Insert replacement keypad with buttons aligned in proper holes.
      Ask FixBot
Author
with
Nichole Shaw
1 Reputation
7 Guides authored
Cal Poly, Team 18-75, Johann Spring 2010 Member of Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 1,487
