LG VX6100 Speaker Replacement
  1. LG VX6100 Speaker Replacement, Front Case: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the four grey plugs using either tweezers or a push pin.
    Ask FixBot
  2. LG VX6100 Speaker Replacement: step 2, image 1 of 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
    Ask FixBot
  3. LG VX6100 Speaker Replacement: step 3, image 1 of 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
    Ask FixBot
  4. LG VX6100 Speaker Replacement: step 4, image 1 of 1
    • The case can now be removed and the interior of the front is accessible.
    Ask FixBot
  5. LG VX6100 Speaker Replacement, Speaker: step 5, image 1 of 2 LG VX6100 Speaker Replacement, Speaker: step 5, image 2 of 2
    • Locate the four solder joints (connected to the yellow, black, blue, and red wires) on the bottom part of the phone, connected to the speaker. It will appear as a black circular part with some holes in it.
    • Place a piece of solder wick on top of the solders.
    • Very carefully, place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • Soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat this step if any solder remains.
    Ask FixBot
  6. LG VX6100 Speaker Replacement: step 6, image 1 of 1
    • After the solder has been removed, pry out the speaker with the plastic opening tool.
    Ask FixBot
Ryan Bishop
1 Reputation
3 Guides authored
Cal Poly, Team 12-39, Regan Spring 2012 Member of Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 46
All Time: 890
