LG VX6000 Logic Board Replacement
    1. LG VX6000 Logic Board Replacement, Battery: step 1, image 1 of 1
      • Locate the dark gray tab on the back of the phone.
      • Push the tab towards the top of the phone to release the battery.
      Ask FixBot
    2. LG VX6000 Logic Board Replacement: step 2, image 1 of 1
      • Lift and rotate the battery away from the bottom edge.
      • Remove the battery.
      Ask FixBot
    1. LG VX6000 Logic Board Replacement, Body: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
      • Only remove the two cushions that are circled!
      Ask FixBot
    2. LG VX6000 Logic Board Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
      • Place the screws on an uncluttered surface or in a small container.
      Ask FixBot
    3. LG VX6000 Logic Board Replacement: step 5, image 1 of 1
      • Carefully remove the back of the phone with your fingernails or tweezers.
      • There are red and blue wires connected to the motherboard. Forcing the components apart could damage the wires.
      • The red and blue wires must be plugged in to reassemble.
      Ask FixBot
    1. LG VX6000 Logic Board Replacement, Logic Board: step 6, image 1 of 1
      • Carefully peel away the adhesive tab.
      • The tab should not be completely separated from the phone.
      Ask FixBot
    2. LG VX6000 Logic Board Replacement: step 7, image 1 of 2 LG VX6000 Logic Board Replacement: step 7, image 2 of 2
      • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
      • Carefully pry the connector away from the motherboard to remove it from the phone.
      • Do not pull forcefully
      Ask FixBot
    3. LG VX6000 Logic Board Replacement: step 8, image 1 of 1
      • Gently lift the corner of the motherboard away from the casing.
      Ask FixBot
Adam Altman
1 Reputation
3 Guides authored
Cal Poly, Team 4-11, Forte Winter 2010 Member of Cal Poly, Team 4-11, Forte Winter 2010
CPSU-FORTE-W10S4G11
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 17
All Time: 3,534
