Up to 20% off select tools
LG VX6000 Keyboard Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
15
All Time:
3,191
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide provides step-by-step instructions for safely removing the battery from the LG VX6000.
    1. LG VX6000 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Locate the dark gray tab on the back of the phone.
      • Push the tab towards the top of the phone to release the battery.
      Ask FixBot
    2. LG VX6000 Keyboard Replacement: step 2, image 1 of 1
      • Lift and rotate the battery away from the bottom edge.
      • Remove the battery.
      Ask FixBot
    1. LG VX6000 Keyboard Replacement, Body: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
      • Only remove the two cushions that are circled!
      Ask FixBot
    2. LG VX6000 Keyboard Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
      • Place the screws on an uncluttered surface or in a small container.
      Ask FixBot
    3. LG VX6000 Keyboard Replacement: step 5, image 1 of 1
      • Carefully remove the back of the phone with your fingernails or tweezers.
      • There are red and blue wires connected to the motherboard. Forcing the components apart could damage the wires.
      • The red and blue wires must be plugged in to reassemble.
      Ask FixBot
    1. LG VX6000 Keyboard Replacement, Logic Board: step 6, image 1 of 1
      • Carefully peel away the adhesive tab.
      • The tab should not be completely separated from the phone.
      Ask FixBot
    2. LG VX6000 Keyboard Replacement: step 7, image 1 of 2 LG VX6000 Keyboard Replacement: step 7, image 2 of 2
      • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
      • Carefully pry the connector away from the motherboard to remove it from the phone.
      • Do not pull forcefully
      Ask FixBot
    3. LG VX6000 Keyboard Replacement: step 8, image 1 of 1
      • Gently lift the corner of the motherboard away from the casing.
      Ask FixBot
    1. LG VX6000 Keyboard Replacement, Keyboard: step 9, image 1 of 1
      • Peel the keypad off the casing.
      • Swap out the old keypad for a new one.
      Ask FixBot
Author
with
Adam Altman
1 Reputation
3 Guides authored
Cal Poly, Team 4-11, Forte Winter 2010 Member of Cal Poly, Team 4-11, Forte Winter 2010
CPSU-FORTE-W10S4G11
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 3,191
