Up to 20% off select tools
LG VX5600 Keypad Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
19
Past 30 Days:
89
All Time:
1,130
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
In order to install the keypad, the bottom portion of phone will have to be disassembled, but the motherboard will not be required to be completely removed.
    1. LG VX5600 Keypad Replacement, Battery: step 1, image 1 of 2 LG VX5600 Keypad Replacement, Battery: step 1, image 2 of 2
      • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
      • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
      Ask FixBot
    2. LG VX5600 Keypad Replacement: step 2, image 1 of 2 LG VX5600 Keypad Replacement: step 2, image 2 of 2
      • Insert your finger into the small indentation above the battery.
      • Push down on the battery and pull it away from the phone; it will pop out.
      Ask FixBot
    1. LG VX5600 Keypad Replacement, Keypad: step 3, image 1 of 2 LG VX5600 Keypad Replacement, Keypad: step 3, image 2 of 2
      • Grasp the edges of the phone with one hand.
      • Unscrew the six 5.0-mm Phillips #000 screws located around the outside of the back panel of the phone.
      • The screws are tight, so you have to use a little force when unscrewing them.
      Ask FixBot
    2. LG VX5600 Keypad Replacement: step 4, image 1 of 1
      • Insert the spudger into the tab at the top of the back panel and push to release the panel.
      • The back panel will then lift away from the rest of the phone.
      Ask FixBot
    3. LG VX5600 Keypad Replacement: step 5, image 1 of 2 LG VX5600 Keypad Replacement: step 5, image 2 of 2
      • Flip the phone open with the back side still facing you.
      • Grasping the phone on the sides, use your fingers to push up on the keypad and motherboard until they release from the phone casing.
      • When you do this the plastic camera button will pop out. It is not directly attached to anything. Make sure to save it for reassembly because it must be placed back on its tab at the side with the camera icon is facing right side up to work correctly
      Ask FixBot
    4. LG VX5600 Keypad Replacement: step 6, image 1 of 2 LG VX5600 Keypad Replacement: step 6, image 2 of 2
      • Lift up the motherboard.
      Ask FixBot
    5. LG VX5600 Keypad Replacement: step 7, image 1 of 2 LG VX5600 Keypad Replacement: step 7, image 2 of 2
      • Grasp the keypad and lift it up and out of the phone.
      • An image of the front of the keypad and phone is shown.
      Ask FixBot
Author
with
Irena Tran
435 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 89
All Time: 1,130
