Up to 20% off select tools
LG VX5400 Phone Casing Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
20
All Time:
2,784
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
If the outer plastic casing of the phone is damaged, it can easily be replaced with these steps.
    1. LG VX5400 Phone Casing Replacement, Battery: step 1, image 1 of 1
      • Turn off the cell phone and turn it over on its back side
      Ask FixBot
    2. LG VX5400 Phone Casing Replacement: step 2, image 1 of 1
      • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
      Ask FixBot
    3. LG VX5400 Phone Casing Replacement: step 3, image 1 of 3 LG VX5400 Phone Casing Replacement: step 3, image 2 of 3 LG VX5400 Phone Casing Replacement: step 3, image 3 of 3
      • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
      Ask FixBot
    1. LG VX5400 Phone Casing Replacement, Outer Casing: step 4, image 1 of 1
      • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
      Ask FixBot
    2. LG VX5400 Phone Casing Replacement: step 5, image 1 of 1
      • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
      Ask FixBot
    1. LG VX5400 Phone Casing Replacement, Phone Casing: step 6, image 1 of 3 LG VX5400 Phone Casing Replacement, Phone Casing: step 6, image 2 of 3 LG VX5400 Phone Casing Replacement, Phone Casing: step 6, image 3 of 3
      • Pry open the phone and remove the keypad and logic board.
      Ask FixBot
    2. LG VX5400 Phone Casing Replacement: step 7, image 1 of 2 LG VX5400 Phone Casing Replacement: step 7, image 2 of 2
      • Lay out and organize the parts of the phone. You can now put the inner parts of the phone into the new case.
      Ask FixBot
Author
with
Tyler
20 Reputation
1 Guide authored
Cal Poly, Team 26-26, Regan Spring 2010 Member of Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 2,784
