LG VX5200 Face Plate Replacement
    1. LG VX5200 Face Plate Replacement, Battery: step 1, image 1 of 2 LG VX5200 Face Plate Replacement, Battery: step 1, image 2 of 2
      • Turn the phone on its back.
      Ask FixBot
    2. LG VX5200 Face Plate Replacement: step 2, image 1 of 2 LG VX5200 Face Plate Replacement: step 2, image 2 of 2
      • Orient the phone as shown.
      • Remove the battery cover by pushing upward with your thumb.
      Ask FixBot
    3. LG VX5200 Face Plate Replacement: step 3, image 1 of 2 LG VX5200 Face Plate Replacement: step 3, image 2 of 2
      • Place your fingernail at the top of the battery and pry the battery out towards you.
      Ask FixBot
    1. LG VX5200 Face Plate Replacement, Face Plate: step 4, image 1 of 3 LG VX5200 Face Plate Replacement, Face Plate: step 4, image 2 of 3 LG VX5200 Face Plate Replacement, Face Plate: step 4, image 3 of 3
      • Flip the phone open.
      • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
      • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
      Ask FixBot
    2. LG VX5200 Face Plate Replacement: step 5, image 1 of 3 LG VX5200 Face Plate Replacement: step 5, image 2 of 3 LG VX5200 Face Plate Replacement: step 5, image 3 of 3
      • Insert the opening tool in the seam of the top portion of the flip phone.
      • Gently pry the seam open.
      • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
      Ask FixBot
    3. LG VX5200 Face Plate Replacement: step 6, image 1 of 3 LG VX5200 Face Plate Replacement: step 6, image 2 of 3 LG VX5200 Face Plate Replacement: step 6, image 3 of 3
      • Close the flip phone.
      • Hold the base of the phone and gently remove the faceplate.
      • Place the phone and the faceplate on a clean, flat surface.
      Ask FixBot
Douglas Blaalid
282 Reputation
8 Guides authored
Cal Poly, Team 4-13, Forte Winter 2010 Member of Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Members
95 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 26
All Time: 2,448
