LG VX4500 Speaker Replacement
    1. LG VX4500 Speaker Replacement, Battery: step 1, image 1 of 1
      • Turn the closed phone so that the back panel is facing you.
      • Press down and forward firmly on the gray tab in the middle of the phone.
      Ask FixBot
    2. LG VX4500 Speaker Replacement: step 2, image 1 of 2 LG VX4500 Speaker Replacement: step 2, image 2 of 2
      • Now just lift up on the battery and remove it from the phone.
      Ask FixBot
    1. LG VX4500 Speaker Replacement, Rear Cover: step 3, image 1 of 1
      • Remove the rubber grommet using a spudger.
      Ask FixBot
    2. LG VX4500 Speaker Replacement: step 4, image 1 of 1
      • Be sure not to lose the screws. They are small!
      • Remove the five screws using a Phillips #00 Screwdriver.
      Ask FixBot
    3. LG VX4500 Speaker Replacement: step 5, image 1 of 3 LG VX4500 Speaker Replacement: step 5, image 2 of 3 LG VX4500 Speaker Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • When removing back cover, be careful not to break the speaker wires.
      • Using an Opening Tool, carefully pry off the back cover.
      • Using tweezers, gently pull the speaker wires out.
      Ask FixBot
    4. LG VX4500 Speaker Replacement: step 6, image 1 of 1
      • Separate the two halves.
      Ask FixBot
    1. LG VX4500 Speaker Replacement, Speaker: step 7, image 1 of 2 LG VX4500 Speaker Replacement, Speaker: step 7, image 2 of 2
      • Take top half of phone and pry up speaker using the Spudger.
      Ask FixBot
    2. LG VX4500 Speaker Replacement: step 8, image 1 of 1
      • Lift out speaker.
      Ask FixBot
David Foster
1 Reputation
8 Guides authored
Cal Poly, Team 25-88, Amido Spring 2010 Member of Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 22
All Time: 2,272
