LG VX4500 Outer Display Cover Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
23
All Time:
1,722
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing the outer display cover.
Tools
    1. LG VX4500 Outer Display Cover Replacement, Battery: step 1, image 1 of 1
      • Turn the closed phone so that the back panel is facing you.
      • Press down and forward firmly on the gray tab in the middle of the phone.
      Ask FixBot
    2. LG VX4500 Outer Display Cover Replacement: step 2, image 1 of 2 LG VX4500 Outer Display Cover Replacement: step 2, image 2 of 2
      • Now just lift up on the battery and remove it from the phone.
      Ask FixBot
    1. LG VX4500 Outer Display Cover Replacement, Outer Display Cover: step 3, image 1 of 1
      • Remove 4 rubber grommets using the Spudger.
      Ask FixBot
    2. LG VX4500 Outer Display Cover Replacement: step 4, image 1 of 1
      • Remove 4 screws using the Phillips #00 Screwdriver.
      Ask FixBot
    3. LG VX4500 Outer Display Cover Replacement: step 5, image 1 of 3 LG VX4500 Outer Display Cover Replacement: step 5, image 2 of 3 LG VX4500 Outer Display Cover Replacement: step 5, image 3 of 3
      • Carefully pry off outer cover using iPod Opening Tool.
      Ask FixBot
David Foster
1 Reputation
8 Guides authored
Cal Poly, Team 25-88, Amido Spring 2010 Member of Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 1,722
