LG VX4400 Antenna Replacement
    1. LG VX4400 Antenna Replacement, Battery: step 1, image 1 of 3 LG VX4400 Antenna Replacement, Battery: step 1, image 2 of 3 LG VX4400 Antenna Replacement, Battery: step 1, image 3 of 3
      • Press the light grey button in the top-center on the back of the phone.
      • While pressing, slide the battery and cover up.
      Ask FixBot
    1. LG VX4400 Antenna Replacement, Antenna: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Unscrew the antenna by grasping the base and twisting counterclockwise.
      • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
      Ask FixBot
Finish Line
Nico Chiarito
22 Reputation
5 Guides authored
Cal Poly, Team 8-47, Regan Winter 2010 Member of Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 39
All Time: 1,824
