Up to 20% off select tools
LG VX3200 Keypad Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
91
All Time:
3,669
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
How to replace the phone's soft keypad.
    1. LG VX3200 Keypad Replacement, Battery: step 1, image 1 of 1
      • Press button labeled "Push". In the photo depicted the button is being depressed by the left finger.
      • Pull back panel toward bottom of phone.
      Ask FixBot
    2. LG VX3200 Keypad Replacement: step 2, image 1 of 1
      • From the lip on the top of the battery, lift it out of the phone.
      Ask FixBot
    1. LG VX3200 Keypad Replacement, Keypad: step 3, image 1 of 1
      • Remove the 4 small screws from the back panel, under the battery, using 00 Phillips-head.
      Ask FixBot
    2. LG VX3200 Keypad Replacement: step 4, image 1 of 1
      • Starting at the top of the phone near the antenna, use a screwdriver or other small tool, maybe even fingernails, to pry the rear panel off.
      • There are 4 places where the panel snaps together to the main part of the phone.
      • By systematically prying up the edges of the back panel, moving about a quarter of an inch, and prying again, the panel will begin to lift off.
      • Don't be afraid to damage anything, the panel requires a bit of force to detach.
      Ask FixBot
    3. LG VX3200 Keypad Replacement: step 5, image 1 of 2 LG VX3200 Keypad Replacement: step 5, image 2 of 2
      • The logic board is only held on with 4 tabs and a data cable in the top right. Simply pry from one side using a screwdriver, popping out the board, before lifting the display data cable.
      Ask FixBot
    4. LG VX3200 Keypad Replacement: step 6, image 1 of 1
      • Lift the keypad up from beneath the logic board.
      • It is not glued or secured in any way, so it should come away easily.
      Ask FixBot
Author
with
Bradley Hutchinson
42 Reputation
5 Guides authored
Cal Poly, Team 5-9, Forte Winter 2010 Member of Cal Poly, Team 5-9, Forte Winter 2010
CPSU-FORTE-W10S5G9
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 91
All Time: 3,669
