Up to 20% off select tools
LG VM720 Volume Button Removal
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
82
All Time:
678
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The LG VM720 is a fairly easy device to handle. Any user with the right set of tools and a basic knowledge of mobile device should be able to fix/replace components related to normal wear and tear.
    1. LG VM720 Volume Button Removal, Power Button Removal: step 1, image 1 of 2 LG VM720 Volume Button Removal, Power Button Removal: step 1, image 2 of 2
      • Remove the back cover followed by removing the battery.
      Ask FixBot
    2. LG VM720 Volume Button Removal: step 2, image 1 of 2 LG VM720 Volume Button Removal: step 2, image 2 of 2
      • With the back panel exposed,begin by removing 10 screws located at the back side of the phone.
      Ask FixBot
    3. LG VM720 Volume Button Removal: step 3, image 1 of 2 LG VM720 Volume Button Removal: step 3, image 2 of 2
      • Using a sharp tool, loosen the edges and slowly detach the front screen panel from the back panel.
      Ask FixBot
    4. LG VM720 Volume Button Removal: step 4, image 1 of 2 LG VM720 Volume Button Removal: step 4, image 2 of 2
      • With the back panel removed,use a screwdriver to remove the power button gently on the inside so it comes off from the back casing.
      Ask FixBot
Author
with
Abdul Rehman Farrukh
101 Reputation
1 Guide authored
USF Tampa, Team 7-3, Leahy Fall 2014 Member of USF Tampa, Team 7-3, Leahy Fall 2014
USFT-LEAHY-F14S7G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 82
All Time: 678
